0 Members and 129 Guests are viewing this topic.
forest
[ author=hartiberlin link=topic=7679.msg245964#msg245964 date=1277045609]
Hi Bruce and ALL,
in the original video, they showed the cooler grill buried in the ground,
but later they used only the waterpipe to ground the circuit and
in the later videos also only ONE groundwire was used.
So it seems to okay, just to use one ground wire.
I guess they just suck out of this good conducting ground
wire the free electrons in resonance.
As the ampereter shows around 22 amps, there you have it.
The Kapanadze circuit must be a High Voltage pulse excited
resonance system for 50 Hz which pumps the 22 amps back and
forth from the ground  to the bulbs via a 50 Hz resonance system.
Otherwise the meter would not work correctly, if there would be
flowing just radio frequency burst pulses in this ground line.
Maybe someone can finally use a pickup coil on a scope
and show us the waveforms, that the Kapagen circuit from
Naudin generates ?
Without using a scope we are just blind with these circuits...
How can we optimize it, if we don´t know the waveforms ?
Many .
Regards, Stefan.
[/quote]
You are 100% correct. This is all related to displacement current between two capacitors and of cource to Tesla patent from 1900 about radiant energy.Still the secret is the way of generating radiant energy which fall on receiver coil which in Tesla patent is just insulated metal plate, but he probably couldn't put detailed description.If you analyse Tesla European patents it is clear that his 'radiant patent' must be investigated together with magnifying transmitter.On one patent is is CLEARLY described how radiant energy from natural or artificial sources fall on metallic plate of device EXACTLY the same as from US patent.
itanimuLLi
jermutin
Quote from: hartiberlin on June 20, 2010, 12:16:44 PM
Many thanks for finding this !
Maybe someone can put this in a PDF file,
it can be read easier ?
Here, @ woofiles (the first no registering file share server that google gave)
http://www.woofiles.com/dl-199241-SWUxriUH-LightAndOtherTesla.pdf
-J
xenomorphlabs
@MrWolf: This thread here is obviously too long. Transcripts of that video
have been posted already multiple times. Since you are a frequent contributor with the nice intent to post info, it would really help this thread if you could do a quick search if the things you want to post have been already posted.
Concerning SR i put an open question:
Based on his statement that he forms a 50 Hz oscillation with transistors and his input voltage is 12 Volt, he is running a push-pull circuit to feed the coil.
Then transform the 6 Volt oscillation that results from the capacitor voltage division up to 220 Volt, he would need a winding ratio of nearly 40.
There is clearly visible only about 100 turns on his coil (not counted the HV winding). Normally you would then use a 2 turn primary and a 100 turn secondary to reach the voltage ratio needed.
I have tried that but the core coverage of the primary is very bad that way and this produces basically nothing. So one would use a much bigger primary,
but SR has only around 100 turns of wire on there.
So how does he achieve 220 Volt in the secondary ???
That is at least how it is described in most interpretation diagrams.
Except he just uses the coil as a current amplifier and then uses that 220 V transformer that he talks about. That would make sense.
Although i always assumed that that transformer would down-step the part of the output back to the input capacitors at 12 Volt.
I am starting to believe that the voltage is boosted somehow.
forest
MrWolf
Thank you. I believe ferromagnetic core is not needed and in fact complicate setup.Soft iron laminated core works also but the optimal would be just air core.
In other words - core is not the source IMHO.
I know at least romerouk is on the right path and also SR.I think I understand theirs caution.
The main problem is not device or replication but understanding energy source and implications of using it for our Earth and (current) mankind.
"Tesla, at the press conference honoring his 77th birthday in 1933 declared that electric power was everywhere present in unlimited quantities and could drive the worlds machinery without the need of coal, oil, gas, or any other fuels. A reporter asked if the sudden introduction of his principle wouldn't upset the present economic system...
Tesla replied, "It is badly upset already." "
How badly is it upset today ? Will we survive that change ?
"Love is the only engine of survival."
