0 Members and 215 Guests are viewing this topic.
tadejstenta
hello,
today i was trying different setups, but no success. After all tests i really believe, that the coil is most important thing of circuit. Today i wind big coil on PVC tube (7cm), that i can move it left or right , but no success.
I added some fotos:
- 170 big coil in middle position
- 171 amp draw (220v) and on variac voltage output was cca. 110V (lamps lit only a Little- next foto)
- 172 1650 (230V) lightbulbs lit only Little with cca 420W input
- 173 FWBR in system, but without caps there was no big difference to compared to the original"   circuit, when i added MO caps - nothing - circuit was not running (thing i need DC caps)
Today best result : lightbulbs almost at full brightness but amp draw 7A 220V. But this result i get also with no coil in the system. In this case i had 2 MO caps in parallel.
I noticed, that is based on lightbulbs brightness, that i get so much how much i put in system (laic observation) and the same results appears with or without coil in system. Today i also try different coils, that is, i rewind it several times.
For now that is all
Tadej
MrWolf
On russian forum they speculated (before SR built device) that Kapanadze core is made from permalloy tape. Also they speculated that inside of that core is this "Ñ...иÑ,рый Ñ,рансÑ,,ормаÑ,ор Зацаринина" = "cunning transformer of Zacaricin".
That's all for now, enough of speculations, time for my own experiments :) Good luck to everyone!
MrWolf
Quote from: xenomorphlabs on June 20, 2010, 01:50:53 PMTranscripts of that video
have been posted already multiple times.
Sorry, I have overloaded my brain it seems, russian thread is also 150 pages and all those Tesla books... :)
Quote from: xenomorphlabs on June 20, 2010, 01:50:53 PMSo how does he achieve 220 Volt in the secondary ???
From the video I understand that mysterious big solenoid coil is just an input for *separate* X=>220V transformer located under other stuff, and everything, including bulb, is powered from that transformer and not from main solenoid.
Quote from: jermutin on June 20, 2010, 01:49:14 PM
Here, @ woofiles (the first no registering file share server that google gave)
http://www.woofiles.com/dl-199241-SWUxriUH-LightAndOtherTesla.pdf
-J
If you don't mind I have enhanced the images and put it into a pdf as they looked washed out.
http://www.woofiles.com/dl-199245-VfGEDBLN-TeslaOnLight.pdf
xenomorphlabs
Quote from: MrWolf on June 20, 2010, 03:10:22 PM
From the video I understand that mysterious big solenoid  is just an input for *separate* X=>220V transformer located under other stuff, and everything, including bulb, is powered from that transformer and not from main solenoid.
That is actually the only thing that makes sense regarding the voltage levels in the big blue coil. If that is indeed the case, then either only the HV winding effecting the magnetic domains of the ferrite core or in addition a special winding arrangement in the blue coil actually necessitate that coil to amplify the current.
Otherwise he could have gone straight into that 220Volt transformer.
I think i´ll try that.
Anyone an idea where to scrap or buy such a 220 Volt transformer?
Most transformers are designed to go 220 -> 12 and have the wire sizes accordingly.
I am curious already what Romerouk will find out with his bifilar winding tests.
If SR is really using an additional transformer then his method is quite different from what Kapanadze is doing, as he does not seem to need anything except his main coil.
