0 Members and 97 Guests are viewing this topic.
xenomorphlabs
Quote from: stivep on June 20, 2010, 07:54:43 PM
Well within 2 weeks I the scientific septic have changed.
After 20 years of  me being with all of my mind in scientific world.
The achievements?
I'm not in here to build my reputation based on my past. I will say it when the time comes.
1.laboratory within 2 weeks
2. International Team of peoples Moscow, Poland-Gdansk, New York the same schematic, the same parts,the same principals.
2. The approach is
FREE  DEVICE NOT FOR PROFIT.
Willingness of changing the way the world is... for better  and the benefit of all human beings..
I'm not afraid to withstand the critics nor I do care...
I'm not afraid to be between and among those who "cant say anything any longer" The simple mistake of every one who achieved the success in this field  was
"Patenting, and capitalizing."
They should of  give it for free. Earning nice and quite life for longer.And maybe some fame.
They decided NOT TO.Now there is only the history that talks about them.
Will I achieve something extraordinary?
NO I WILL NOT!!!!!!!!!!!!!
The EXTRAORDINARY  was developed by Nikolas Tesla
We are only followers of his dream.
Thank You
I will see what is the response of the peoples in forum before I direct you to my YouTube.
You guys certainly have the right test equipment in your lab and obviously some background in scientific methodology.
It is good to see that there is people researching this not as blindly as most of us, because of lack of complex measurements of what we are actually doing and what waveforms are involved.
Looking forward to what your investigations will result in.
Are you basically trying to build the exact Kapanadze set-up or do you have a modified concept in mind?
Bruce_TPU
Quote from: MrWolf on June 20, 2010, 04:41:07 PM
How totally wrong! Try it yourself. It's nothing like permanent magnet. It does not attract anything else, does not even move compass! But both parts stick together like strong magnets. When I break the configuration by force and try just to stick them together again they dont stick. Do not attract anything else also.
Anyone who thinks this is ordinary permanent magnet has not tried or is disinfo agent. I have technical degree and I do fairly complex stuff @ work, so I know when I see permanent magnet and when I see something else...
Over and out.
Hello Wolf,
You have said several things that have peeked my interest.  Please post the circuit that your are using to flip the ferrite domains using a spark gap!  I find it a facinating idea, indeed.  Also a picture of them attracted to one another.
Many Thanks!
Bruce
hartiberlin
I corrected the audiotrack of the SR193 video with the english subtitles and
uploaded it to youtube over here:
http://www.youtube.com/watch?v=rbkvXoDfk7g
Many thanks for the translation and the subtitles.
Regards, Stefan.
Bruce_TPU
Stefan, Wolf and ALL,
Did all of you catch the following when watching that video? I think I have the answer!!
Working backwards:
4:34  He says "from OUTPUT TRANSFORMER power goes to 220 Volt transformer BELOW and closed loop is formed"
4:15  He says "OUTPUT COIL powers the bulb"
4:12  He says "Transformer is powered by Output coil"
4:08  He says  "After that all is connected, THEREUNDER is TRANFORMER FOR 220 Volt"
SOLUTION:
1.  Ground wire (EDIT TYPO OF COIL) goes through center of core.
2.  Core is Ferromagnetic
3.  INSIDE OF Ferromagnetic CORE is 220 Volt TRANSFORMER!!
4.  OUTSIDE OF Ferromagnetic CORE IS WRAPPED THE OUTPUT COIL!!
OUTPUT Coil then powers the BULB, AND 220 Volt TRANSFORMER!
That is how he did it!!
    8)
Cheers,
Bruce
xenomorphlabs
Quote1.  Ground coil goes through center of core.
What ground coil?
How can a 220 Volt transformer be INSIDE of the core?
This clearer picture shows the 220 Volt transformer UNDER the blue coil.
Looks like 100 Watt or more.
