0 Members and 93 Guests are viewing this topic.
Bruce_TPU
Ground Wire, NOT ground coil, my typo!
I believe he is using TWO transformers!
The Ground wire goes through the Core.  Then he says "Below" and "down under" in reference to the "Output Coil".  What would the result be of putting a 220 V transformer in a ferromagnetic core, with and "output" coil running through it?  I believe this is WHY there has to be a ferromagnetic coil.
It is NOT what you can see, but what is NOT seen...as usual.  And it is WHAT HE SAYS that is important!  (if the translation is accurate!)
Cheers,
Bruce
Edit:
OK! I see that the Transformer is indeed UNDER the Output coil.  So it is closed Loop, Output coil to 220 Volt transformer and Bulb.  Transformer to Spark Gap and Spark gap Wire Also going through Ferromagnetic Core.
Edit #2
But, there are still more wires through the core as one can see... The big one is the TP 5, that is the ground.  One is the Wire from the spark gap, goes through the core and too where?  And the other one? Where is it from?
stivep
Quote from: grizli on June 20, 2010, 08:19:38 PM
I am sure 99% people totally agree with you here ..
Yes they should... and history repeats when such things are patented like OU devices... , and it will repeat and repeat. We all here witnessed that many times.
NO WE ARE NOT TRYING TO REPAT KAPANADZE
We are trying to take advantage  from everyone who contributed in this field
I have  perfect fluency in at least 3 of Eastern European Languages
That gives me access to all of the Slovian root of linguistic similarities.
Isn't that surprising that   all of the success in the area of Tesla Invention originated from this part of the world,  including Nicolas Tesla by himself ?
The progress in partnership for NO MONEY and our the position in this area is as fallow:
1. In Poland Jacek was able to light the light bulb from HV
2. The signal representation in laboratory is investigated  in reference to Lo Voltage and High Voltage signals.
3. You do not have to geest what is relay going on   when we finish we are willing to give it up.
4. The explanation is in Polish but major factors are in English
http://www.youtube.com/watch?v=9Q8r2ikJtZ0
Bruce_TPU
Okay!  Here are a few more wires that can be traced.
A really amazing video, selfrunning.  I have not seen something so captivating, since Steven Mark's TPU.  This appears a MUCH safer way to generate self sustained power!  This video has me very excited!!
Cheers,
Bruce
EDIT:
The wire with the question marks, appears to be the ground from the transformer.  That is all I can deduce, but I think it a good start!!
Bruce_TPU
Last Post of the night...
First let me say, I know that the drawing below does not have the Capacitor, or the heavy duty transistors, etc.  But is simply a "roughing idea" of which wires are through the core.   If I have missed anything, please feel free to draw it in.
Perhaps Groundloop or someone skilled with circuits can put together a reasonable semblance based on the video.  There seems to be enough in the video, to make a decent attempt at a circuit.
Cheers,
Bruce
EDIT:
at 3:40 in the video, he mentions and you can see a SECOND transformer.  He states that the transistor generates a signal to this transformer, and this HV transformer ignites the SG.
flathunter
[A author=stivep link=topic=7679.msg246068#msg246068 date=1277091582]
[/quote]
Wow!
Thats quite a setup on the youtube vid - well done stivep and keep up the good work!!!!
Maybe someone fluent in Polish can translate and add subtitles??
