0 Members and 39 Guests are viewing this topic.
jeanna
Quote from: justasm on July 07, 2009, 03:26:05 AM
Hi everybody ;)
There is so much interesting ideas, facts and thoughts and for me - it is good start, but it looks like everybody just tries to replicate something that somebody already done with possibly positive results without knowing that for sure.possible in very easy way ;)
JustasM
Hi justasm,
Here is the reason I replicate things.
I am not a trained EE either. For me it is the easiest way to learn what has been done before. I usually don't need to replicate too many things to get a pretty good understanding of what is going on. So, after only one or 2, I start to put my own ideas into it.
Right now, I am seemingly alone.
I am wanting to use ac in amounts other than 120 volts and at frequencies of other than 60 hz, (I am in US), but although others say they are interested, they are not joining me.
I have been working with the joule thief which can be used as an AC generator.
I have heard many times, "...then we can rectify it and do something useful"...
The only "useful" things trained people think of are always DC. (!)
Even our Georgian inventor, has turned his output into DC.
The reason I am alone is that what I am wanting to do is never done. It has never been pursued by anyone in the field after Tesla.
So, Tesla is my only source.
Tesla discovered something, but no one ever followed what he did, and what he discovered has remained hidden. (Hopefully we can re-discover it.)
As an aside, I personally believe that overunity will never be found by sticking with DC. (Others have disagreed, and that is fine.)
But, justasm, please jump into the sandbox and play.
All are welcome.
We are all in this together!
jeanna
xenomorphlabs
Audio analysis of frequency of the loud tone emitted from Kapanadze device when he switches it on.
A tone of 410 Hz is clearly audible, this is a harmonic of 51.25 Hz (~50 Hz playback speed of analogue camera might distort the freq.)
I wondered why there is such a loud sound. Is that possibly coming from the coil (singing) and it is keeping on singing also when its running on its own at the same freq just more quietly.
Would that be the resonant frequency it is keeping itself at?
Then it has to be noticed that it is indeed a multiple of 50 Hz.
This is from the shorter video where he has everything in a glass box.
I have also noticed that one of his spark gaps seems to nearly operate at a 1 Hz freq, very slow, you can hear it. It might be simply a safety gap though (which makes more sense).
Maybe this info is of any use for Groundloop and potential replicators,
*** i mean after all he wants to put out usable AC (which is either 50 or 60 Hz) ***
EDIT : Not sure about the last statement- there is too many diagrams and the feedback is
sometimes omitted. So i assumed he needs AC on the output to feed AC to the input, right?
But if you assume not having an AC device on the input, but a battery, then a DC output would make more sense. Never saw a rectifier on the output too.Jenna pointed out to me that some translation spoke of him wanting to go to DC.
So sorry for a confusing statement.
EDIT 2: I have found the following statement in the patent W02008103129A1 :
This electric energy formed by the second bobbin adjusts the necessary frequency (220 V -50 Hz or 110 V - 60 Hz) for use, by the help of second frequency adjuster designed at the bobbin output.
So this clearly calls for an AC output except they failed to mention a rectifier put after that.
This patent could not be more vague,really ! *ROFL*
Anothertruthfinder
Hi all  :D decided to hook up to this one i get a good feeling, thats interesting @xeno roughly an octave differential - some of the tests ive done with earth ground (guitar lead plunged into the ground brought indoors) and a radiator,12v 12ah sla,  variable pwm 100hz(from ebay :)), ignition coil and toroidal transformer (2x115 - 2x15 ), bridge rec and some ceramics show me that it is possible to create many harmonics - i manged to get around 1.75khz at one point but 100hz elsewhere in the cricuit at the same time. Spark gap really needs to be very well tuned i think cause ive seen that make radical differences to in and out voltages. I'm very much basic in all this but i just try concepts whatever the weather  ;)
i managed to spike my speakers a real gooden - loud! - at certain frequency and spark gap tuning it was really sending out a field quite far i was getting worried someone would complain - i just thought id encourage everyone to try different configs with hv transformers etc. and reasonant tuning - its a matter of time.  ;D
eel
Pirate88179
Jim:
Thank you for your kind words.  Would you mind posting your scope shots of your earth battery here showing the freq.?  If I remember correctly (which hardly ever happens) I think it was in the kHz range.
Thanks.
nievesoliveras
Quote from: jeanna on July 07, 2009, 12:59:41 PM
jeanna
The AC and DC Voltages will always be used alternating between them.
The electronics field is composed of both voltages.
Almost all the electronic gadgets we have on our houses convert voltage between AC And DC on the same circuit.
Saddly one without the other cannot do all the work needed to complete a task like running a computer for example.
Jesus
