0 Members and 145 Guests are viewing this topic.
wings
exnihiloest
Quote from: e2matrix on June 20, 2010, 06:27:05 PM
Also a double pole double throw switch or relay would be nice to take it off the mains once it is running and looped.  If you got light then you have just hit the jackpot!   And it would seem to be an easy way to show whether this is OU or not.
I agree and I already said the same. I would like this to be the only method for any device before claiming OU.
The below was suggested by a not so cooperative person. You can call it "On the effects of a high voltage coil/field near a transformer". According to him the fan will speed up near the high voltage coil. Can someone with a high voltage setup confirm this?
stephenafreter
@All: info about D'arsonval cited by Don Smith is already available in English online, on this great website : http://www.electrotherapymuseum.com
See these very detailed books that explain a lot about Tesla' tech:
http://www.electrotherapymuseum.com/Library/CurtisHighFrequencyApparatus/index.htm
http://www.electrotherapymuseum.com/Library/Strong/index.htm
And an original book by Tesla himself:
http://www.electrotherapymuseum.com/TeslaArchive/OnLight/index.htm
Available in pdf format here, thanks to Broli:
http://www.woofiles.com/dl-199245-VfGEDBLN-TeslaOnLight.pdf
baroutologos
ADMIN:
Hi Bruce and ALL,
in the original , they showed the cooler grill buried in the ground,
but later they used only the waterpipe to ground the circuit and
in the later videos also only ONE groundwire was used.
So it seems to okay, just to use one ground wire.
I guess they just suck out of this good conducting ground
wire the free electrons in resonance.
As the ampereter shows around 22 amps, there you have it.
The Kapanadze circuit must be a High Voltage pulse excited
resonance system for 50 Hz which pumps the 22 amps back and
forth from the ground  to the bulbs via a 50 Hz resonance system.
Otherwise the meter would not work correctly, if there would be
flowing just radio frequency burst pulses in this ground line.
Maybe someone can finally use a pickup coil on a scope
and show us the waveforms, that the Kapagen circuit from
Naudin generates ?
Without using a scope we are just blind with these circuits...
How can we optimize it, if we don´t know the waveforms ?
Many thanks.
Regards, Stefan.
i have pointed out several times again. How is it possible to suck 20 amps at 50Hz or even 400Hz from earth to whatever device? I have estimated you need an "ONE TERMINAL CAPCITANCE" of 100-500uf
Most of Tesla coil's single terminal capacitance is 50-200pico-farards. Some 6 orders of magnitude lower. This is imposible. Actually Tesla tried to tackle this issue (Colorado Springs notes 88-89pp. This is a big question mark also.)
For the experienced in this technology and whoever can understand what i say in technical terms not in "ather" bs-tology, this is a big question mark similar in size that of free energy in Kapanadze device.
Tackle with this, and you tackle with kapanadze device secret.
