0 Members and 150 Guests are viewing this topic.
Quote from: Pirate88179 on June 21, 2010, 05:19:07 AM
Broli and others as well.  Please keep your photos to no larger than 800 x 600 otherwise it messes up the entire page and folks have to then use a scroll bar to read all of the posts.
I have re-sized the photo.  Thanks for posting it just please use the proper sizes.
Thanks,
Sorry about that. But it should be quite an easy solution to convert any attachment to below 800x600 with some javascript. The image html tag already supports custom resolution for any image.
baroutologos
It is not about mystery, it is about making magnetic transistor and controlling big forces with small forces. I have also made purely mechanical magnetic transistors based on the LaFonte Group work.
Wolf,
You refered to magnetic transistors, if such thing existed then an OU device would be a piece of cake after that. As far i know this does not exist. My latest experiments on MEG, that some have proposed the assumption that a small flux (controlling coils) controls a larger flux (PM flux) just holds no true.
http://www.energeticforum.com/renewable-energy/4231-bedinis-kromrey-converter-21.html#post99712
What's your experience on magnetic transistors? Can you enlighten me?
EDIT:
Whoever gets in trouble and read my posts and analysis, he will discover that a FORCE that results from a B-flux is exponetially related to the flux that creates it. (closed loop setup)
On the other hand, electricity creation is linear related to the flux that permeats a core over  coil is wound.
Thanks,
Acca
"Will I achieve something extraordinary?
NO I WILL NOT!!!!!!!!!!!!!
The EXTRAORDINARY  was developed by Nikolas Tesla
We are only followers of his dream."
stivep1
It looks like there is allot of money spent on this equipment to prove that Tariel Kapanadze did discover Tesla principles by studying his lectures. I hope I can keep up with you. I speak Polish and live in the USA, I too, am building the Kapanadze device, however I am more practical as to use the experimental methods of building and changing variables on the device.. Let the RACE to discovery begin... I hope to post my Kapagen device videos soon.. Thanks for your "Scientific" aproach... Al …
Also please see post #193 the Pdf file by By Vladimir Utkin u.v@bk.ru, this is one of the most important documents that has surfaced,
"Use additional special “kicking” coil, which can generate short powerful magnetic pulses, and install amplifying Tesla coil along the electrical vector of the E/M field of this coil."
G. Vasilatos, Secrets of clold war technology, chapter 2, states that Tesla discovered that the "staccato pulsing of ONLY a DC current, accelerated the magnetic collapse, causing voltage to be present with no current, the generation of electrons in metals, that where the current component came from, the source of current is the metal as it gives off electrons for power..
And that is what powers all these lamps in the Kapanadze device. What is needed is a large surface area of the grounding rods, an array or multiple grounds, then sheet copper ribbon should be used to connect all grounds, remember you want to capture all the free electrons that are generated.  As to the coil what is shown, the coil produces an-unbalanced DC pulse, in the magnetic field a core of iron will work better than an air core as it concentrates the flux in the center, however due to eddy currents the collapsing field is just too slow for that effect, what is faster is a ceramic iron that will not have any residual magnetism under the the pumping action of the current. This is why the Russians are so fixated on ceramic iron in the Kapanadze device, I have built a center core that is made of Metaglas with a very fast switching speed.
This is also very important..
"Negative mass electrons and negative mass positrons" generation by the "kicking coil"
When one solves Maxwell's equations for propagating electromagnetic photon energy, the solutions allow for negative energy photons as well as the ordinary positive energy photons. Negative energy photons would be given off by negative energy electrons and that would cause circuits to run cool. That is what is seen with the better free energy devices.
Al...
baroutologos
Just to schematically represent my above point regarding Kapanadze phenomenal device capacitance.
(since one image = 1000 words)
MrWolf
Quote from: baroutologos on June 21, 2010, 05:39:21 AMYou refered to magnetic transistors, if such thing existed then an OU device would be a piece of cake
Kapanadze has "magneto-electrical" transistor. I have "magneto-mechanical" transistor which involves enough conversion losses to make it hard to handle.
Look up LaFonte Group Switcher. I can 100% confirm the effect. By applying laughably small force on the shaft you can control big forces in the core of device. To apply force on the shaft you can use any means you like.
Constructing COP > 1 device on this effect is another matter and would need substantial investment and calculations. I just wanted to confirm the effect.
I prefer not to talk about overunity but about devices with COP > 1 that use energy of the environment. Such devices are for example refigerator and other heat pumps.
You can make "closed loop" heat pump. If you manage to convert heat back to electricity with sufficent effiency. Of course actually it is an open loop system because of input from the environment...
Also you can make self-sustaining heat pump without electricity when you have big potential difference or very precise engineering.
I know people who have no water pumps in the heating system of their houses (working on big potential difference).
Same thing is with Kapanadze generator. It is open loop system utilizing energy of the environment.
But enough of offtopic... Over and out.
PS. Dont bother with equations and stuff :D Tesla did not bother also, he just tried to make bigger bang than before ;)
