0 Members and 177 Guests are viewing this topic.
grizli
Quote[ author=baroutologos link=topic=7679.msg246118#msg246118 =1277119436]
@Exnihiloest,
This is my view also from a practical point of view. I have also find out that the force to dimantle a double C core closed flux path circuit is almost exponential to the flux flown inside. Anways..
Back to our topic
I urge anyone interested in Kapanadze device and who has basic understanding of Tesla oscillators backed-up with hands-on experience, and have read Colorado springs notes (especially on enhanced single terminal capacitance suggestions by Tesla 88-89pp) to comment on my views on single terminal capacitance and participate in the discussion.
My comment is : WATCH my post before few pages where I posted link to Russian Kacher TC circuit.. ANWER is there ...
QuoteAgain REWATCH this...
Is this just capacitive effect or radianth effect related to tesla patent with elevated plate for recieving radiating energy ?
http://www.youtube.com/watch?v=tbwpie_OtqU&feature=related
Now compare this with thick copper rod inside Kapanazde coil , and with video "strange russain transformer"
So WHY bulb work there is NO TRANSFORMATION of current ... we have HV at the top of TC and insiginificant current.... but again bulb works. and determined by bulb voltage of that plate near TC can not oscilate more than 220V...
So will 1mhz at 220V for that plate capacity make enough power ? capacity of that plate near is probably 16pF. and OF IT OSCILATES AT about 1mhz if I am corrent that about 0.4 W.. WHY THAN light bulb works ?
Classic TC reciver tranmistter has miny turn and low turn wire ... load is connceted to low turn wire ... we here have only metal plate near TC ...
EXPLAIN that ... and probably you sill explain how kapanadze device work
exnihiloest
Searching for LTspice model (that I didn't find) for electric arcs, which could be a key point of the Kapanadze device, I came across a new today's article on arXiv:
"Modeling Vacuum Arcs"
http://arxiv.org/abs/1006.3770
May be of some interest even if this one concern arcs in vacuum.
MrWolf
Quote from: baroutologos on June 21, 2010, 06:56:43 AMBTW basic equations and "stuff" do apply. if you have read a little about Tesla you have surelly pointed out that he made a LOT of calculations and stuff.
Well that's a double edged sword, Tesla still was a great experimentator rather than great calculator ;) Don't you find strange that we all are gathered here because of a uneducated man like Kapanadze, rather than because of a some kind of hi-end doctor-person?
Also most world-changing findings are made by people who did not care much about state-of-the-art science...
Of course perfecting these findings is another matter ;)
baroutologos
Grizzly
Griz, i have done those experiments. With the Kacher and a metal plate near it and the Zatsarinia single-rod transformer. They are not OU in any case.
Concelrning the russian youtube video you mention (http://www.youtube.com/watch?v=tbwpie_OtqU&feature=related ) and has been discussed before, There is a capacitative coupling between Kacher's coil and a metal plate that goes to ground via a load. In best case the lamp can be lit at 50-70% efficiency that is fed to coil. (this is how much i have achieved and everydoby else so far. If i am wrong state setups and experience)
You calculate
An 16pf of single terminal capacitance (is that only 16pf??? Note the capacitance of the bulb + wiring till there is added) of the metal plate and you suggest a nominal 200volt to be achieved or a 300+ and 300- at each charge of capacitance cycle and you make the calculations.
amperage = capacitance x voltage x frequency x 2 (two times the cap is charged)
amperage = 16/1.000.000.000.000 * 300* 1.000.000 * 2 = almost 10mA
A typical 40 watt (assuming this is 40 watts if not less) at 220 volts to be fully lit requires approx 200 mAs (it is not fully anyway) so according you logic it is impossible to light that lamp. Correct. So something "radiant" must be there?
WHo told you that the metal plate near the oscillating kachers gets only +300 to -300 capacitative coupled voltage????? You say so because the lamps operates at such nominal mains volatge?
This is quite irrelevant.
Easily the metal plate can reach a couple of thousands volts near the Kacher.
@Wolf,
Kapanadze is an achitect. He is not uneducated man. And apparently he is very talented in many aspects.
WHO TOLD YOU, state of the art tech has not OU?
Because you wont find it in the shelf to buy it?
MrWolf
Quote from: baroutologos on June 21, 2010, 08:24:50 AM
I would suggest to study magnetic viscosity. OU trick is to do action and get out real fast before reaction. In "physics laws" there is said that there will be reaction, of course it will :) But does law say WHEN? Just COP > 1 can be done without such trickery.
