0 Members and 275 Guests are viewing this topic.
xenomorphlabs
@Bruce_TPU: I appreciate that you want to discuss the SR set-up.
Please refer to these very clear diagrams by Andi to understand the origin of each cable
at the coil:
http://www.001-lab.com/001lab/index.php?topic=4.msg10791#msg10791
http://www.001-lab.com/001lab/index.php?topic=4.msg10917#msg10917
http://www.001-lab.com/001lab/index.php?topic=4.msg11517#msg11517
The wire coming from the spark gap is NOT going THROUGH the core, but is wound like a solenoid single layer ON TOP of the core.
The corresponding wire is blue on the left side and orange on the right side.
The wire with the question mark can possibly be one side of the primary of the 220 V transistor .
baroutologos
I would suggest to study magnetic viscosity. OU trick is to do action and get out real fast before reaction. In "physics laws" there is said that there will be reaction, of course it will :) But does law say WHEN? Just COP > 1 can be done without such trickery.
Any evidence that leads to the contrary? Any setup made upon that you say?
wattsup
Very sorry to interject into your thread here but I have followed this thread on and off.
My only question is, has any of the guys that have a test unit with the grounds already in place every just tried this test as shown below.
I would like to know just if you put the two grounds into the ground and connect them to each side of a coil, like the longest coil in your builds, what will a compass reading show.
Will it be.
No polarities.
North Top and South Bottom
North Bottom and South Top
All North or all South
Center position ?????????
Then just keep the connections the same way and turn the coil so the top coil end is now on the bottom and the bottom end is now on the top. Then do the same readings to see if they have changed in any way.
If anyone had done this test could you please find the post.
Thanks in advance for any info.
Hunch, I am hoping it is all North if the person lives in the Northern Hemisphere.
Keep up the good work.
wattsup
xenomorphlabs
@MrWolf:
Concerning your description on your idea of the Kapandze process.
It is as good as any others, because we all can only speculate.
A critical point in your argument is point 9)
If the transistor pair would be merely used for switching purposes with a comparatively low on-time then the heatsinks AND fan would look a bit overkill.
At least in SR´s set-up. I run about an amp through them (full-time) and they don´t get critically warm.
And where would you see the necessary connections to the 220 Volt transformer?
Besides SR himself has said that they are bipolar powerful NPN and PNP transistors used to form a 50 Hz sinusoid waveform and you can clearly see them connected in the standard push-pull configuration.
The kicking of the ferrite also implies that the domains must relax after being kicked which is difficult to control.
You will find in russian forums that people prefer to excite the domains rather with a frequency in the kilohertz range to bring the ferrite to its resonance.
You will furthermore run into all kinds of bizarre transmutation speculations.
I personally don´t see enough pre-conditions (especially field strength) for this to be even remotely likely.
SR has stated also that he uses HV in the frequency range of 25-35 kHz and most likely uses a fixed-frequency inverter board.
grizli
Quote from: baroutologos on June 21, 2010, 08:24:50 AM
Griz, i have done those experiments. With the Kacher and a metal plate near it and the Zatsarinia single-rod transformer. They are not OU in any case.
e)
They ARE OU... but problem is that KACHER itself is inefficient oscilator: I presume effcienty of KAcher oscilatir is LESS Than 35%
Quoteamperage = capacitance x voltage x frequency x 2 (two times the cap is charged)
amperage = 16/1.000.000.000.000 * 300* 1.000.000 * 2 = almost 10mA
A typical 40 watt (assuming this is 40 watts if not less) at 220 volts to be fully lit requires approx 200 mAs (it is not fully anyway) so according you logic it is impossible to light that lamp. Correct. So something "radiant" must be there?
It is known that Radinth is related to Electrostatic... BY CORE behavour of this setup it behaves STRANGELY.... TC = HI current at the bottom and HV at the top... if you want to wiresly burn ligth bulb you need another TC to collect HV electrostatily and convert it to high current : low turn coil... WE here have ONLY capacitor directly to load...
Now lets see : I read that kacker is about 20-30% eff... and that small TC has low Q... much resistance(akin effect, distributed C etc) .. there you drop half of the energy for sure .... Lets sey that 100W bulb (Russian rutube channel destine) works about 70% eff with only 35-40W of imput power : ADD to that so LOW efficinet kacker + low Q tesla coil + heating of TC (resistance of wire, skin effect atc)
Lacher has NO C.. and can probably behave AS class A amplifier.. in theory it CANT have more than 25% eff.
QuoteWHo told you that the metal plate near the oscillating kachers gets only +300 to -300 capacitative coupled voltage????? You say so because the lamps operates at such nominal mains volatge?
This is quite irrelevant.
Easily the metal plate can reach a couple of thousands volts near the Kacher.
BUT ground one end put plate near TC ... and TELL me HOW can TOP plate be near 100kV(lets say we have 100kV TC in the test)
IT clearly oscilates about +/-200V ant 70% eff...
HOW CAN there be 25kV  on that plate  of its connected with series with bulb and grounded.. it DEFIES BASIC law of transformation ....
Only radaint energy can do that.. and that has been explain in Tesla patents with elevated plate ... near radinth energy .. etc
SORRY for bad English , and typos :D
Note to all people here : Stop doing police work and investigating SR.. that way you will NEVER find answer, cause there has been 200 forum pages on Russian forums without success..  my opinion is thats waste of time... probably its easy to start from scratch like KApagen ..
