0 Members and 185 Guests are viewing this topic.
forest
I see you are starting to grasp how easy it can be.
First rate of change - Faraday law of induction allow us to use weak field faster to get the same effects as using strong field slower.
Earth field is weak.Earth field is huge and device  is in area of one pole. Now, two N N or two S S magnetic poles push themselves away.If you see magnetic field lines seems to be squeezed.
We put small magnet inside huge one pole Earth magnet and preferably one pole should be inside and OPPOSING pole outside pushing away Earth field (bow shock).You can do it fast or slow , not matter - this is when we have to put energy (doing is fast means  smaller energy is needed). What is important is very abrupt collapse of our magnet so Earth field will reconnect.And there is inertia with every energy and mass so it will be longitudinal wave of contraction and then opposite like heart beating.You have to have device in resonance with that and form open path separate from original power source, open path connected to Earth electric subsystem - here is flowing high frequency radiant energy,between positive air and negative ground.Recreating lightning using radiant energy (electromagnetic pulse) to generating displacement current in Earth capacitor.
That's why I asked to show magnetic field around small magnet placed inside huge magnet pole.Now you see that problem is two-kind :
- a method of generating radiant energy
- optimal coils embodiment to have smooth field having one pole inside surrounded by other pole (and opposite to Earth)
No more theory  ;D I did found it the simplest possible.
MrWolf
I made some progress in mean time.
Discovery 1: If SR setup is not a hoax altogether then IMHO it is not Kapanadze setup, I have pretty solid info what it actually is (from academic sources). But I will not publish it until personal build/verification, which will take sadly at least month if it is possible at all. I see no other way because this thread is aldready out of hand and full of disinfo. Some of it is put here on purpose some of it is due to misinterpretation (like my version of SR device inner workings, but I still suggest to experiment with sparking of ferrites).
Discovery 2: If Naudin setup (which is IMHO not Kapanadze setup also) resembles anything "Tesla" at all then it is this: low Q version of Oudin oscillator. And replication will never work correctly unless built to exact specs and discovering a correct and gentle (90 degree?) way to harvest generated potential:
http://www.physics.gla.ac.uk/~kskeldon/PubSci/exhibits/E8/
"It is basically a high frequency Tesla transformer with the bottom end of the primary and secondary coils connected together and firmly grounded."
Discovery 3: It's time for everyone to learn Russian :D Most of you have not a slightest idea how far are some russian guys gone and what experiments they have done. Also you can get lots of very radical information in russian from academic sources and old scientific magazines.
Example: In 1939 Russian scientists discovered that it is weak terahertz range radiation that controls the cell reproduction and other functions in living organisms. Radiation is created by organisms themselves. Now add new terahertz range airport scanners and word cancer to this equation...
grizli
Quote from: MrWolf on June 22, 2010, 06:22:23 AM
Discovery 2: If Naudin setup (which is IMHO not Kapanadze setup also) resembles anything "Tesla" at all then it is this: low Q version of oscillator. And replication will never work correctly unless built to exact specs and discovering a correct and gentle (90 degree?) way to harvest generated potential:
Example: In 1939 Russian scientists discovered that it is weak terahertz range radiation that controls the cell reproduction and other functions in living organisms. Radiation is  by organisms themselves. Now add new terahertz range airport scanners and word cancer to this equation...
HAN WHAT is KApanadze setup ? if it is not related to Tesla ?
What is SR setup ?
MrWolf
Quote from: grizli on June 22, 2010, 08:27:48 AMHAN WHAT is KApanadze setup ? if it is not related to Tesla ?What is SR setup ?
IMHO Kapanadze device is related to Tesla. Naudin setup also. But Kapanadze and Naudin setups are different, Naudin' is rather Oudin coil. But SR device... Appears that SR193 just did dig up something totally different and not related to Tesla coils, but styled it to look like Kapanadze to make himself look cool. That's why he was extremely reluctant to give out any information.
At least I see it all that way. Time will tell. Maybe only working one is Kapanadze's ;)
grizli
Quote from: MrWolf on June 22, 2010, 08:47:07 AM
WHAT SR digged , tell us ?
Ferrite magnetize with low powers and currents somehow *
