0 Members and 184 Guests are viewing this topic.
Coruscant
Here is a vid of my attempt at a kapagen showing the 1200watts of lights lit fully from the mains with no ground connections:  (input volts 115vac 60hz at 9.8amps... due heating, otherwise when cold it reads out 9.5amps)  Load is bank of 5 x 240watt 120volt lamps. (not high enough impedance likely, prolly need a bank of 20 lamps at 80watts each at 120volts... better impedance match to the MOT's output resistance of the secondary perhaps...)
http://www.youtube.com/watch?v=AYW0zMt-dU4
and here is a vid showing the magnetic field (as best I could anyways) that is setup off the MOT as a result of the spark gap firing:
http://www.youtube.com/watch?v=88d8jE2lVSo
I went and looked at JLN's old ver 3 vid that showed the blue box open and the MOT has its axis vertically aligned with its Side towards the air core that is the laminates.  The side with the turns is towards the spark gap but theres sufficient distance there that perhaps the magnetic field isn't interacting with the spark gap (or maybe it is and is being drawn into the circuit there as gain?)
My spark gap is already two carbon graphite rods in aluminum ground lugs so that although it gets smokin hot, nothing melts.
Anywho check it out and fill me in on any suggestions on what to try next.   I'm in process of stripping 6 lengths of Cat5 cable to make the "bundle of copper insulated wires" that look like they are in JLN's core of his air core.  I'm hoping this changes the dynamic as it will be 48 x 24awg wires all insulated with just their ends shorted together like seen in the pics.
Ossie,  did you end up trying this?  was there any good result?
Regards,
Coruscant
gnino
Hi watch again this video http://www.youtube.com/watch?v=r7C1b7-w3Hs
the bulb is on whitout HV and spark gap  when turn on  hv the light increase
i think i a sort of magnetic amplifier whit hv an spark gap instead of battery
sorry for my english
now write in italian somebody can translate if is not clear
ciao la lampadina e accesa anche quando lo spinterometro non è attivo, quando viene attivato la luminosità aumenta ,penso sia una sorta di amplificatore magnetico con alto voltaggio e spinterometro al posto della batteria
ciao
vrand
Quote from: broli on June 22, 2010, 12:46:23 PM
A heads up to some new developments from jnaudin:
http://jnaudin.free.fr/kapagen/index.htm
Less apparent power, more bright lights.
Jean Louis writes:
In the Kapagen v3.3, the spark gap has been finely tuned, a plasma cloud is created between the gap, there is no audible sound from the sparks. The input power has significantly dropped to about 153 W while the 14x150 W light bulbs connected at the ouput are very bright in spite of the surrounding sun light... The Kapagen is an attempt of replication of the Tariel Kapanadze generator. More infos at www.jlnlabs.org
Looks like Carbon electrode on one side and Copper on the other that is creating the plasma.  Interesting   :)
baroutologos
:D
Someone in this thread? or another one, has posted a link to an old book (scanned) that described ways of making a Tesla like oscillator. Actually in that book it has some description of influence of HF HV at plants..
Anyway, that author described the ideal spark gap as the quenched one. He did not call queched spark-gap the one blown out with air or with a magnet. He discribed it as two lathed out thick/heavy metal plates, more like short/ wide metal rods that are used in TC primary.
Those wide/short and heavy metal surfaces have a distance some 1/8 or 1/16 of inch, i cannot recall well, and will produce a smooth - according the author- discharge that greatly enhance TC perfomance.
I cannot really see how the quenching can happen in that large surface/small distance... but that what the man has written anyways.
ps: If someone remembers the link of it, a repost is of no harm
Coruscant
@baroutologos...
Are you talking about the D'Arsonval book that someone finally found that Smith referenced?
Perhaps quenching the gap isn't so much about blowing out the arc as it is about having enough mass of metal there to draw off all the energy being allowed into the circuit at the spark gap, which likely would require a decent chunk of metal for both electrodes.  Then the quenching is the ability of the arc to dissipate out into the load?
I've not been able to find that book for a reasonable price firstly and second my french is horrible so I'd probably only benefit from any schematics if D'Arsonval put them in there.  He seems to have been quite the young doctor in his day.  :)
I can try rounding the faces of the carbon that I use for both sides of my spark gap to see how that works out...   You can see in JLN's vid that the carbon gets red hot and takes on a red tinge while running...  The way my faces of the carbon electrodes are now are just flat faces and the arc moves around within the faces and isn't held to a single point like the JLN gap appears to be with those shaped electrodes.   I wonder where he got a carbon lug like that.
Regards,
Coruscant
