0 Members and 174 Guests are viewing this topic.
kalem
Quote from: MrWolf on June 22, 2010, 09:12:47 AM
Yep, low power, thats why he only managed to light one . I will consult with experts in couple of days. If they tell it has substance then I'll publish, otherwise it will lead everyone far away from Kapanadze/Naudin (high power!) devices for no good reason.
Do you have more info on components which SR193 used in his device, especially capacitor which is rounded with red in the image of the scheme? All other components can be calculated more or less easily. Scheme seems ok. Do you know of any successful replication? It doesn't matter that the output is only 150 W if it is self-looped.
It seems like Fe56 to Fe54 transformation by feromagnetic resonance, not like Kapanadze device with "kicking" coil. Just guessing.
wings
Quote from: vrand on June 22, 2010, 01:53:58 PM
Jean Louis writes:
In the Kapagen v3.3, the spark gap has been finely tuned, a plasma cloud is created between the gap, there is no audible sound from the sparks. The input power has significantly dropped to about 153 W while the 14x150 W light bulbs connected at the ouput are very bright in spite of the surrounding sun light... The Kapagen is an attempt of replication of the Tariel Kapanadze generator. More infos at www.jlnlabs.org
Looks like Carbon electrode on one side and Copper on the other that is creating the plasma.  Interesting   :)
posted by aether22in "Solved! How Edwin's tube and Paul Baumanns machine works.":
"William Barbat in US patent Application #2007/0007844 describes (possibly theoretical) ' mass' electrons being generated by a copper oxide (copper readily oxidizes in air and quickly at high heats as would have been the case for Tesla's Sheets) coating being struck by light, this is interesting as Teslas copper plates would have very likely oxidized before being coated, Barbat's theory of this enhancing loose coupling transformer operation may also be true but what I have read of his theory of why is nonsense unless these electrons produce a diminished magnetic field and with it less self inductance.
These  mass electrons are also found by mainstream physicists sometimes, in carbon, a material which as I will cover seems ideal for generating these cold electrons, see: http://www.intalek.com/Index/News/PhysicsWeb%20-%20Electrons%20lose%20their%20mass%20in%20carbon%20sheets.htm
Stiffler (and whoever else composed 'ATGroup'?) found these cold electrons in the TMB or Thermal magnetic battery, though the accuracy of the name is disputed.
http://67.76.235.52/tmb.asp
Despite the extreme  voltage a cold blue are was noted:
"Cold Blue Arc.   When a load is connected or disconnected to a TMB cell an arc can bee seen of approximately 1/16" in length. This arc is light blue in color and not something typically seen in normal electronic circuits. The arc is wide compared to its length and is quite broad in size when initially appearing.
This is extraordinary since the voltage output of a TMB is somewhere from 50-300mv, very very low voltages to be producing an arc of about 1.5mm when the normal requirement would be 1,500v to breach a 1.5mm gap, a voltage 5000 times high than found from even 2 TMB's in series.
Also note the arc is again 'cold' suggesting that these electrons didn't transfer much kinetic energy either due to their lower mass or like the electrons in a superconductor they tend to avoid interaction........"
I think it is oxidized copper by heating.
wings
grizli
Quote from: wings on June 22, 2010, 04:52:16 PM
Despite the extreme low voltage a cold blue are was noted:
it seems high oxided copper by heating
With normal GAP Naudin got 220W... now he gets 150W  ... but itself his device behaves very good no matter what SparkGap used
Yes his spark look very weird... hmm
xenomorphlabs
All nice looking, but Kapanadze had nothing as fanzy.
The big difference between Naudin´s and Kapanadze´s device is
that Naudin ONLY has the High Voltage path and Kapanadze seems
to have 2 paths (the other one probably  low voltage/ high current).
So Naudin wants his  to look like Kapanadze´s  but in Kapanadze´s HV voltage path there is with a high probability only a fraction of the current.
That´s why he can get away with simple Copper rods for the SG, which would smoke at currents higher than 30mA.
Quote from: xenomorphlabs on June 22, 2010, 05:38:26 PM
So Naudin wants his spark to look like Kapanadze´s spark but in Kapanadze´s HV voltage path there is with a high probability only a fraction of the current.
That´s why he can get away with simple Copper rods for the SG, which would melt at currents higher than 30mA.
I think there's more than that difference. What's inside the green box or whether he uses a ferrite core is one big mystery, and it would be ludicrous to assume there's no precise timed switching going on. The box most definitely contains the timer circuit and the high voltage transformer.
Currently there's:
-Exciting environment
-Releasing energy from copper
-Releasing energy from ferrite core
The latter came to me after I reminded myself of steorns patent. The lag to a magnetic field change. What if a strong but extremely short pulse was given to the primary coil, the ferrite's domain will start aligning while the pulse is already dead, thus there's no induction. However a collector coil can now gather the inductive energy of the ferrite as the domains relax. In short the primary coil is pulsed with a burst of energy, the ferrite will lag this field and align while the primary coil is no longer energized. When all domains are aligned and about to relax again the secondary collects the inductive energy.
I know, another baseless theory. But just something to keep in mind as well.
