0 Members and 139 Guests are viewing this topic.
HeairBear
LOL, maybe I misunderstood you...
That's just it, a transistor will never be fast and sharp enough to do the job. For a joule theif? Yes. For a Tesla coil or anything of the likes? No.
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
xenomorphlabs
Quote from: jeanna on July 07, 2009, 07:24:04 PM
I just found the translation I was looking for
It is the part that says the lights are DC quite specifically, and from a georgian friend of xeno's, So, I guess he speaks the language. (I got to wonder after all.):
- Every lamp is 1 kWatt
Now he makes a voltage measurement at the water-pipe ! :
- 4 Volt or milliVolt
- Volt
- Alternative or direct current?
- Direct
- 6 Volt is shit
So, if the lights were DC lights (and the thickness of the wire also supports this possibility) what is being used as AC?
@jesus, I do hope it really is an AC device. I was discouraged by this translation.
I added the info to the quote.
The voltage reading was not related to the lights at all.
At 7:55 in the video you can see it for yourself. It was a camera cut from the lamps
right to the guys measuring the voltage at the water pipe.
So i am quite sure there is AC being produced at the end.
The patent even speaks about it as 1 phase, which would be obsolete information for DC
and even suggests the addition of more secondary coils for more phases.
So i hope you don´t worry anymore Jeanna ;)
Transistors are really inferior to spark gaps and they also never completely isolate
the circuit. However a fully solid state version of this should be attempted.
In Kapanadze`s latest version, the device is so small that i doubt he has HV-caps and spark gaps in there, but i might be wrong.
BTW : An interesting similar concept can be read about here : http://jnaudin.free.fr/html/parabifc.htm
I am running some simulations on the different circuit ideas and i stumbled across an inherent
conceptional mistake in the circuit that groundloop cleaned up (not his mistake of course but circuit designer´s)
The issue is, that for the N-type MOSFET to conduct it would need a control signal from the MOSFET controller. But this controller can logically only get a signal after the first current flows
in the secondary circuit. For this to happen the primary circuit would have to energize the coil, which won´t happen because the MOSFET is closed and "waits" for its control signal to open.
So the cat hunts her tail here.
Certainly this could be overcome by introducing an auxiliary circuit that kicks off the MOSFET one time and then let´s it run.
This error supports my feeling that this circuit was an early design idea and is far from the final version. If you have a look at Kapanadze´s 2nd video you can see a lot of circuitry in there on Printed circuit-boards. I am currently translating a russian document that has the most advanced
circuit design so far, indicating that the russians are significantly advanced in their replication efforts.
Stefan will like this, it adds to his statement that the earth is playing a role in the resonance as the earth ground is electrically connected to the core of the main transformer and the lamps (!)
In fact while translating it, it seems that the earth wire IS the only core in the main transformer
jeanna
Yes Heairbear,
My experience is with a joule thief with bifilar primary and 1 or 2 secondaries.
Off one secondary, I have lit a 7 watt fluoro tube for 6 hours and a 15 watt one for 5 1/4 hours. So, that is pretty good lighting for starting with a 1.2v rechargeable AA.
It is not the toaster, but it us a start, and using this design  with the secondary it produces very high frequency high voltage only milder.
It draws less amps from the battery with more load.
Many people are getting these results.
Now, if I can get 450 volts looking either like ac or very pulsed dc (I can get it both ways) from a 1.2 volt battery, what will I be able to do with a 12 volt?
I am personally not ready to try this.
If you or someone else more skilled than I wants to try, I will be gratefully watching.
thank you,
jeanna
edit,
@xeno,
Thanks, that looks hopeful.
HeairBear
OH! I see what you are getting at, I think. It just so happens that I have a Wilby built JT circuit in my possesion he built for me to help me with replicating pirate's stuff. I think Wilby is experimenting with something similar to what you are describing. I don't know for sure though.
electricme
@Jeanna,
Quote from: jeanna on July 07, 2009, 08:03:38 PM
:D OH dear!
Do you like winding all your coils under oil?
jeanna
Coils are not wound in "OIL", :D   they are wound in "air" then if it is designed to run in an oil bath, it will either be placed in oil, or placed in a suitable container, then the oil will be poored in.
Take a look at the pole pigs. ;)
jim
