0 Members and 687 Guests are viewing this topic.
dllabarre
Quote from: hartiberlin on June 26, 2010, 07:51:31 PM
@JuJu,jermutin and scratchrobot and the other new members,
welcome to the forum and many thanks for the additional infos.
many thanks .
Regards, Stefan.
Stefan
Please check your PMs.
Thanks,
Don
vrand
Quote from: Acca on June 26, 2010, 03:33:57 PM
Here is the video link to the KapaGen, that the photos represent in my previous post, there is no audio because it was recorded in hi speed 210 frames per second video. http://www.youtube.com/watch?v=x6wVwYYZqeg
P.S. I have just uploaded the video to my "magnetflipper" channel on YouTube, it may take a while for it to spread across the net.
Nice setup Acca, looking forward to seeing the unit in operation :)
Are you using carbon and copper electrodes on your spark gap?
Thanks
bolt
IMO no point making a "work of art" till you have a proven solution. So much time and money spent on something which may not work for you. IF on the other hand this was a fully working unit THEN it might be worth spending the extra on FRILLS to make it last. If you enjoy making models and art then your RE research funds going to require millions!
I know people that spend fortunes on making the TPU and Don Smith coils buying in pure silver wire, gold crimps, HV caps that cost hundreds of bucks each.   Zero oxygen 1000 strand soft copper cables, spark gaps machined so nice they look stolen from the Marconi museum with  special brass fittings mountings on polished wood base.
and guess what?
It works EXACTLY the same as mine i made in 15 mins. FK ALL! :)
As seen now maybe up to 50 or so replications in various forums and only about 2 or 3 have results that is worth writing home about. So many question the measurements which have more or less resolved as JLN stated "i turn up voltage to start device which consumes 900watts which then requires voltage reduction so that the device  only consumes 211 watts"
So there you have it. Most of the 50 replications could work if they controlled the voltage current and JLN meter is fairly accurate as he can and does see 900/1000 watts i/p UNTIL he tunes and lowers the voltage. This in itself destroys the myths of a huge error on meter as if they device is not retuned after starting the meter will see 1000watts i/p for 1000 watts o/p = no OU non tuned.
As with almost all OU devices OU comes first from i/p power savings techniques and THEN you will start to see OU later.
If you don't have a variac only 2 AC motor runs caps required. Start on series mains 100uf to get the thing going then drop to approx 5-20uf (find best value) to maintain lowest current i/p while arc is just operating.
JuJu
thank you for the advice, i think romerouk does not have any variac or caps at mains, and he still have good results, but for now, we cannot know for shore, if the output current is the same on a 1000W system, that the one with adjusted lower input 200W. Maybe JNaudin can put a naice motor onload that needs large current, that will be great.
have allready someone suceded with measuring output?
im working on small scale version for now, because will be difficult to me to try to reloop this brute force system, im testing just 300 volt on the primary, and just one lamp on load, if i dont suceed at low HV, i will try the flyback tranformer... and i have some other different ideas in mind to!
will share some good stuff soon, anyone knows what should be the pulsed frequency to make this kind of coil work: http://www.youtube.com/watch?v=0R1pxae9K9c , it was allready posted here, but i just wanted to take that doubt!
hugs :D
Quote from: bolt on June 26, 2010, 10:29:53 PM
retrod
IMO no point making a "work of A" till you have a proven solution. So much time and money spent on something which may not work for you. IF on the other hand this was a fully working unit THEN it might be worth spending the extra on FRILLS to make it last. If you enjoy making models and art then your RE research funds going to require millions!
and guess what?
Odd that I cannot find another video other then the one I made on the 16th that shows and describes the "dialing in" process of turning up this circuit. http://www.youtube.com/watch?v=n7G60lVJW8Q Yes, a variac makes it very easy. It reminds me of the days when I was operating old tube type transmitters with the tuning of the plate & grid current :)
I have not been able to reproduce the 'arcformer'/'sparkformer' method of Mr Naudin...yet. I agree on starting with a simple build that will allow easy and running changes as required.
RD
