0 Members and 965 Guests are viewing this topic.
JuJu
good to see you here my friend!
good luck with your setup and i hope you share also!
hugs
Quote from: scratchrobot on June 26, 2010, 07:33:41 PM
Hi JuJu,  my first post here also, maybe this is a better place to continue the experiments, don't know why
they are acting that way? I also want to build one next week  :)
scratchrobot
vrand
Quote from: retrod on June 26, 2010, 11:36:08 PM
Odd that I cannot find another video other then the one I made on the 16th that shows and describes the "dialing in" process of turning up this circuit. http://www.youtube.com/watch?v=n7G60lVJW8Q Yes, a variac makes it very easy. It reminds me of the days when I was operating old tube type transmitters with the tuning of the plate & grid current :)
I have not been able to reproduce the 'arcformer'/'sparkformer' method of Mr Naudin...yet. I agree on starting with a simple build that will allow easy and running changes as required.
RD
Thank you Dave, I missed your video on the alum. foil experiment but found it at
Aluminum Foil Attracted to Floor
http://www.youtube.com/watch?v=eMglSpDA36k&feature=channel
Very interesting effect!  :)
You are transmitting HV through the air and ground that Tesla talks about.  Do you think it is HV AC or DC?  I have read that Sparks are AC and Arcs are DC.  What do you think it is happening with the gas tube spark gap, is it changing HV AC to DC?
Notice any difference when using the 3 gas tubes vs the single mercury lamp?
How did the Krypton gas tubes work out?
Do you feel a "pressure" coming off the gas tubes when you put your hand close to it?
I have lots of other questions on your design, as you are the only one using gas tubes, and that changes the kapagen design significantly, IMO.   :)
Do you "dial-in" tuning with a variac?  Yeah, I did not see that video.
Also have you tried bringing close the the gas tube a small piece of alum. strip to see if it is attracted to the gas SG?
Thanks, Mike
baroutologos
Here is the  link to the KapaGen, that the photos represent in my previous post, there is no audio because it was recorded in hi speed 210 frames per second video. http://www.youtube.com/watch?v=x6wVwYYZqeg
P.S. I have just uploaded the video to my "magnetflipper" channel on YouTube, it may take a while for it to spread across the net.
Really pro work there. You are way above equiped any experimenter i have seen.
Who are your investors? :D
By the way it is imperative the device to possess tunning tools
Variac, spark-gaps, coil, grounds possitions and loads all should be adjustable.
Of course, i will agree with Bolt here, the first step is to fine-tune the system so as to cut input to minimum for maximum performance. This requires some experimetation time and then becomes obvious.
Output should be measured then.
flathunter
[A author=JuJu link=topic=7679.msg246746#msg246746 date=1277609642]
im working on small scale version for now, because will be difficult to me to try to reloop this brute force system, im testing just 300 volt on the primary, and just one lamp on load, if i dont suceed at low HV, i will try the flyback tranformer... and i have some other different ideas in mind to!
will share some good stuff soon, anyone knows what should be the pulsed frequency to make this kind of coil work: http://www.youtube.com/watch?v=0R1pxae9K9c , it was allready posted here, but i just wanted to take that doubt!
hugs :D
[/quote]
I'm going the same direction juju - small kapagen with no deadly MOT that will undoubtedly finish off an FE novice like myself.  12V battery and 30KV power supply....i want a 40W filament to light up first, and then ill feel like i might be able to make the sucker into an OU device.
Had real problems getting on this thread for the past 4 days...dont know whats wrong - are the MIB already interfering with my net connections???  They must know how close I am  ;D  Anyone else experiencing difficulties?
Good luck guys!
xenomorphlabs
Quote from: flathunter on June 27, 2010, 04:49:15 AM
hugs :D
Good luck guys!
I´m interested in what you will find out, i tried the same kapagen coil but with flyback and 9KV NST and couldnt get not even the smallest lamp to do anything.
So i assumed that this needs some serious amps.
Good luck.
