0 Members and 1051 Guests are viewing this topic.
forest
Quote from: xenomorphlabs on June 27, 2010, 07:34:41 AM
I´m interested in what you will find out, i tried the same kapagen coil but with flyback and 9KV NST and couldnt get not even the smallest lamp to do anything.
So i assumed that this needs some serious amps.
Good luck.
Yes and no.It simple require special discharge of capacitor and repeat it fast enough or put a feedback to maintain oscillations. The best way is to mix low voltage with big amperage with tiny HV spark.Check also wattsup posts from Understanding electricity in TPU thread
xenomorphlabs
I talk about hard experiments, TPU theory and "it´s all so simple-posts" don´t get me anywhere.
JuJu
have you tryed the circuit from groundloop?
he is using a plasma ball HF/HV generator, without almost any current also, and his doing great... also dragon had sucess with the NST!
hugs
Good luck.
scratchrobot
Thanks for the welcome  :)
I'm gonna try to build the  tomorrow and want to experiment with an transformer from an plasma globe first, I also have a flyback transformer from an old monitor.
Maybe I should make a smaller coil ???
http://www.youtube.com/watch?v=4QYaR9HR-tM  Playing with HV Plasma Globe powered by small solar panel.
I think it has even sound modulation build in ;D
scratchrobot
retrod
Quote from: vrand on June 27, 2010, 12:19:12 AM
Thank you Dave, I missed your video on the alum. foil experiment but found it at
Aluminum Foil Attracted to Floor
http://www.youtube.com/watch?v=eMglSpDA36k&feature=channel
Very interesting effect!  :)
You are transmitting HV through the air and ground that Tesla talks about.  Do you think it is HV AC or DC?  I have read that Sparks are AC and Arcs are DC.  What do you think it is happening with the gas tube spark gap, is it changing HV AC to DC?
Notice any difference when using the 3 gas tubes vs the single mercury lamp?
How did the Krypton gas tubes work out?
Do you feel a "pressure" coming off the gas tubes when you put your hand close to it?
I have lots of other questions on your design, as you are the only one using gas tubes, and that changes the kapagen design significantly, IMO.   :)
Do you "dial-in" tuning with a variac?  Yeah, I did not see that video.
Also have you tried bringing close the the gas tube a small piece of alum. strip to see if it is attracted to the gas SG?
Thanks, Mike
Hi Mike, I am doing more bench testing with the Mercury lamps, see this video
http://www.youtube.com/watch?v=gImh43w3hjs
I have not looked further into the aluminum foil , there are already plenty of lifter videos published and it appears to be the same activity taking place. The Krypton tube I purchased off ebay was unsuited for this work, a hyped up ad and the product a wimp, beware! The Mercury lamps are robust for testing, the one that glows pink in the video was 50 cents American  :).
