0 Members and 132 Guests are viewing this topic.
vrand
Quote from: retrod on June 27, 2010, 01:01:39 PM
Hi Mike, I am doing more bench testing with the Mercury lamps, see this video
http://www.youtube.com/watch?v=gImh43w3hjs
I have not looked further into the aluminum foil , there are already plenty of lifter videos published and it appears to be the same activity taking place. The Krypton tube I purchased off ebay was unsuited for this work, a hyped up ad and the product a wimp, beware! The Mercury lamps are robust for testing, the one that glows pink in the video was 50 cents American  :).
Hi Dave, thank you for the video and info update  :)
Yeah, the mercury gas bulbs are definitely producing electrons ejecting out.  Be careful it is not x-rays. Great idea of using the photo tube in picking up the electrons and amplifying it to a speaker, sounds of mercury spark gaps  ;D
Do you plan on adding a ferrite core to the kapagen coil to test the theory that is what Kapanadze was using, similar to SR's design?
The addition of the ferrite core, with a open hole in the middle (stacks of donut ferrites), reminds me of Wilbert Smiths Caduceus-wound Coil design.
http://www.zamandayolculuk.com/cetinbal/caduceusexp.htm
Have you ever experimented with the Smiths Caduceus coil?  Lots of strange effects reported. Maybe can use the mercury gas tubes in pulsing it.   :)
Thanks, Mike
xenomorphlabs
Quote from: flathunter on June 27, 2010, 04:06:38 PM
Im only here for experiments Xeno - theory and the rest of it always went over my head.  ???
Will hopefully get some youtube vids up soon - and like i said, im only gonna be using a battery or NST....
Couldnt you even get a 75 W bulb alight with your NST??  Coil, or no coil, i would have thought it would light up.....I managed to get 2 40 W bulbs and a 75 W fairly well lit with my 6.5 KV NST.  I wasnt so impressed as its pretty much the same result when i put the same load on the secondary of my Tesla coil, which uses the same NST (also going to ground...but only one ground here)...
Flathunter,
thanks for sharing that. I seriously think that my earth ground is no better than hanging an open-ended cable out of the window then lol. It must be due to the bad earth connection which is a bombed out building with a 30 cm layer of soil and trees and plants above it. Unfortunately professionally testing a ground connection is tedious and requires special equipment.
I really couldnt get anything to light not even a 15 watt bulb. It was a 8KV NST and i used the romerouk kind of coil after the spark gap.
What kind of circuit did you use?
flathunter
Quote from: xenomorphlabs on June 27, 2010, 05:08:28 PM
Flathunter,
I really couldnt get anything to light not even a 15 watt bulb. It was a 8KV NST and i used the romerouk kind of A after the spark gap.
I used a 24/80/6 coil.  spark gap of various materials - all worked.  With the NST I was using a polyprop cap (same as in my TC).  NOTHING would work unless i had both grounds.  I wanna try another NST i have which is 8 KV, but without using the cap in the same circuit.....
Most importantly, I wanna see if everything works without the coil.  It seems to me it will work just as well......
Photos and vids coming soon.
baroutologos
Hello at all,
I just re-saw Tomb455 replication of Kapagen. It seems at some time that his lights, although dim enough are lit with 0.15 (@150V of variac?) . This is less than 35watts.
If this is so, then for me OU is there. You cannot just light 10 lights as such with 3.5w each.
Anyway, i gave some thought and found out an easy solution for measuring input current using analogue means. The below diagram is self explained.
Just use a strong FWBR as KBPC3510, (35A, 1000V) and apply the analogue meter accordingly. The you have a VERY good indication of what is going IN.
Please all experimenters consider it. (I will do it as my time will come!)
EDIT:
Below photo is to give an idea how is the topology
Transformer out, clamp meter, bulb work in ac, analogue meter in DC
forest
I think it is important to test what happen if extra coil is not connected to secondary coil as at the attached  picture !
