0 Members and 123 Guests are viewing this topic.
xenomorphlabs
Very good points.
Here is an interesting document about testing earth ground resistance
http://support.fluke.com/find-sales/Download/Asset/2633834_6115_ENG_A_W.PDF
It is unfortunately not just doable with a multimeter.
Probably the decisive factor in the differences of i/p amp draw of the various replicators is to be found in their earth ground resistance.
I had noted that too, how Tesla was going meticolously into detail about the set-up of his grounding.
k4zep
Hi Gang,
You might want to digest this link to understand the operation of the MOT power supply and the problems measuring accurately
the input current.
http://deanostoybox.com/mot_power_supply.htm
Won't touch the output with a 10 foot pole in trying to determine the power available as  MOT is much more robust that most think.
I'm working on this but simply won't post anything until I can accurately show what is going on and if the grounds are really doing anything or not.
Ben K4ZEP
grizli
Quote from: baroutologos on June 28, 2010, 03:49:26 AM
Hello at all,
I just re-saw Tomb455 replication of Kapagen. It seems at some time that his lights, although dim enough are lit with 0.15 (@150V of variac?) . This is less than 35watts.
If this is so, then for me OU is there. You cannot just light 10 lights as such with 3.5w each.
Anyway, i gave some thought and found out an easy solution for measuring input current using analogue means. The below diagram is self explained.
Just use a strong FWBR as KBPC3510, (35A, 1000V) and apply the analogue meter accordingly. The you have a VERY good indication of what is going IN.
Please all experimenters consider it. (I will do it as my time will come!)
EDIT:
Below photo is to give an idea how is the topology
Transformer out, clamp meter, bulb work in ac, analogue meter in DC
http://www.youtube.com/watch?v=keIBU5F3jwo
only 0.15 A ?
grizli
Quote from: grizli on June 28, 2010, 12:23:06 PM
only 0.15 A ?
http://www.youtube.com/watch?v=3xGGhcHmIK4
Look here, he use wire INISDE tube ? !!!
HF goes outer surface  .. what he gets if he puts wire INSIDE tube does this makes difference
2:37
vrand
only 0.15 A ?
Thank you for the info, as I missed seeing TomB455 videos!  :)
Those 10 lamps 150 watt bulbs = 1500 watts output!
Found at JLN Kapagen Project Book:
The Worldwide KAPAGEN experiment replications
http://jnaudin.free.fr/kapagen/replications.htm
Very impressive. Looks like OU to me.
Keep up the good work TomB455 !!   :)
