0 Members and 771 Guests are viewing this topic.
the_big_m_in_ok
Quote from: dllabarre on June 28, 2010, 09:42:10 PM
There has to be a way to measure the output safely and accurately.  ???
There's a post on this site with a graphic drawing of how to do that, but this is what I can give you now:
http://en.wikipedia.org/wiki/Voltage_divider
His drawing did exactly the same thing.
--Lee
JuJu
If someone want to open his eyes, Im actually driving lamps of (from the mains grid):
100W (220 V AC x 0.455A) with ----> 13,37W (91V DC x 0.147A)
60W (220V AC x 0.275A) with ----> 9.46W (91V DC x 0.104A)
25W (220V AC x 0.112A with ----> 4.95W (91 DC x 0.045A)
http://www.youtube.com/watch?v=hQLur_YFd3M
this means that with an input power of 180W/16, you can easily light lamps quite bright with just 11.25W output each!
im using a 1N5408 (Half DC Rect.) and a 20W 300OhmJ resistance in series with load!
at the end of the video i show a 25W bulb lightning is filements with just 30VAC and a few miliAmps!
all the 555 timer circuits of 50Hz that i tryed with my step up transformer will not give me 220V output onload!
anyone have one that would work with my setup and could share?
hugs
xenomorphlabs
JuJu
of the timer circuit/transformer?
12V, 2 amps input... im using this circuit: http://web.archive.org/web/20080601042020/http://www.uoguelph.ca/~antoon/gadgets/servo3.htm to activate a TIP31C transistor...
the transformer is I/P 220V 50Hz O/P 10V 1A , but im using it reversed, to step up!
the neon onload its at 90Volts... but the bulb, the maximum i get was 45V
i would expect to run this quite brightly with 220V and 45mA
but my circuit is not working good at all, dont know what to do...
jeffsmathers
I'm almost finished with my initial configuration and have some 'ground' work to do in the yard.  I'll try to attach a photo.  I am anxious to try a water bath type calorimetry to show correlation of input and output.
