0 Members and 196 Guests are viewing this topic.
Pirate88179
@ Jeff:
Very nice clean looking build you have there.  I wish you the best with it.
wings
Quote from: forest on June 28, 2010, 04:00:33 AM
Friends,
I have found something extremally invaluable !
Read it here : http://www.capturedlightning.org/hot-streamer/TeslaCoils/Misc/PracticalMagnifierConstructionPrinciples.pdf......
coupled, oscillation transformer, fully obeying simple transformer action
The critical requirement of this driver is that it has the lowest
possible impedance with reference to ground. Having said this, it can be seen
that two critical requirements must be met.
The first is the very finest ground connection must be secured! The casual
coiler cannot begin to appreciate this statement. Tesla once said that the bulk
of the expense for the Wardenclyffe tower was in the incredibly deep and
labor intensive grounding system he required in order "to secure a firm grip
upon the earth".
see fig5  :( :( :(
http://www.google.com/patents?id=ojk5AAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q&f=false
ramset
Forest
I know Tesla was building a tower close by me in shoreham longIsland ,
It was /is right on long Island sound.
What do you think about using the sound[salt water] or a lake for testing/getting a good ground??
Thanks
Chet
Thanks Grandma
xenomorphlabs
Quote from: JuJu on June 29, 2010, 12:32:35 AM
of the timer circuit/transformer?
12V, 2 amps input... im using this circuit: http://web.archive.org/web/20080601042020/http://www.uoguelph.ca/~antoon/gadgets/servo3.htm to activate a TIP31C transistor...
the transformer is I/P 220V 50Hz O/P 10V 1A , but im using it reversed, to step up!
the neon onload its at 90Volts... but the bulb, the maximum i get was 45V
i would expect to run this quite brightly with 220V and 45mA
but my circuit is not working good at all, dont know what to do...
You mention ONE transistor ?
How do you hook the transistor up to the timer and the transformer/ lamp?
Concerning your mains lamp experiment. How did you measure the current and where exactly?
JuJu
its easy...
the timer output is just activating the transistor base, the primary from the transformer, one side goes to positive, and the other to colector of transistor! is this not right?
concerning my experiment, i have read the voltage between the diode positive, and the negative of load! and the amp draw, between the end of the resistance, and the lamp positive! its all very clear in the video...
if anyone still have doubts before seeing my vid: http://www.youtube.com/watch?v=hQLur_YFd3M
that is FULL PROOF that a bulb off 100W will light up naice bright with just arround 10W input!
you can see this guy movie:
http://www.youtube.com/watch?v=k-0zM41AyiY&feature=related
there's clearly a relationship between, input and brightness... and he is using transformers at the output to do measuraments, guess what?
anyone can prove me wrong? maybe bolt?
i dont think so... 50Hz timer circuit, anyone can help?
