0 Members and 175 Guests are viewing this topic.
JuJu
so how will i make currect measurements?
yeap, DC measurements before the 1N5408 (half dc rectify)...
whats wrong with my measurements?
Quote from: xenomorphlabs on June 29, 2010, 12:15:07 PM
I think your method of measurement is incorrect.
You did make DC measurements?
So all you did is rectify the AC ?
JuJu
have you seen my video?
i have not used any KAPAGEN setup...
this is just to prove that the lamps of 100W will light with just arround 10W input from the main grid!
Quote from: grizli on June 29, 2010, 12:29:19 PM
Do you use classic Kapagen setup here ?
JuJu
i guess you will have to be satisfyed with this one... or you have another choice, TEST IT YOURSELF!
blurry meter shots? are you blind in someway? just put the video in full screen and put pause when the meter is showing readings... its easy to see when im measuring current and voltage if you are familiar with DMM's!
first i show voltage across 60W lamp, and then 100W lamp... 91VDC
then i show amp draw of 100W lamp (147miliAmps), then 60W lamp(104miliAmps), and last 25W lamp(45miliAmps)!
this is full proof that a lamp of 100W will light up with just 13W input from the grid... and 13 watt is 13 watt... with 91VDC at 147miliAmps, or with 220VAC at 60miliAmps
please dont atack me, im just here to find out the truth colegue!
hugs
Quote from: bolt on June 29, 2010, 12:49:12 PM
There is no circuit diagram he is using one diode and one resistor in series with the bulb. The YT vid is basically VERY unclear with no circuit, no narrative, crap music, no overlay caption showing clearly what the readings are basically don't worry about it ..........move along.
If you want to make a decent video then SPEAK clearly, show a circuit diagram, use captions to show readings as shaky blurry meter shots are crap and NO Fking MUSIC!!!!
flathunter
If you want to make a decent A then SPEAK clearly, show a circuit diagram, use captions to show readings as shaky blurry meter shots are crap and NO Fking MUSIC!!!!
Thats a bit rough - the music was real good!  and you got to hand it to juju...hes been a busy lad recently with lots of builds.  Thats what we need.
JuJu
pulsed DC? where is the pulsed DC in my setup?
is just 220AC sine at 50/60hz, half rectifyed to DC!
Quote from: bolt on June 29, 2010, 12:35:47 PM
Those digital meters either read pure AC sine at 50/60hz OR pure DC they will not read pulsed DC on AC readings nor will they read pulsed dc on dc settings correctly.
