0 Members and 123 Guests are viewing this topic.
Acca
Woopy: You may have to use a water pipe ground on one of the connections, as and alternative to the first ground. The ground area has to have salinity for good conductance you may have to a take Megger tester and determine a good spot.
What is a megger test?
If you are refering to a Megometer, it is a test of the insulation properties of such things as electric wiring, motor windings and high power antenna mounts. We use a "megger" or "meg out" electrical wiring and equipment to see if it is shorted to ground in any way. The megger uses much higher voltages to check resistance than a normal Volt-ohm meter. Ideally, you want infinity resistance but I've installed 460 volt motors with 750 megohms resistance to ground and had no problem.
This device will tell you what resistance you have in the ground as it shoot Hi-voltage in to your ground rods and meter will tell you what conductance you have in the Ohm mega value , so you may find the right spot quickly.
Please check the latest video by tombest67 on YouTube
http://www.youtube.com/watch?v=3xGGhcHmIK4
Acca...
JuJu
thank you bill, is naice to have your support, cause i admire very much your work, been folowing your videos from sometime ago!
no offtopic here, we are just trying to improve the concept...
do you have some inverter or timer circuit, that will work with my step down transformer  (I/P 220VAC 60HZ 0/P 10V 1A), im using it reversed as a step up.
in theory if i pulse 60HZ 10V at 1Amp at the primary, i should get 220VAC 45mA at the output... this way i will light the 100W bulb with just 10W... (instead of 13W using 91VDC)
and i can test another transformer that i have here... I/P 220VAC 60HZ O/P 9V 200mA, to see if i can light it with just (9Vx0.2A)  1.8Watts!
but i am not getting any sucess with the circuits that i have tryed.. :(
or maybe you can suggest a better idea? please you are free to purpose!
Quote from: Pirate88179 on June 29, 2010, 03:42:28 PM
JuJu:
I appreciate your efforts in your experiment to show bulbs lit with 10% input power.  Now, if you go one step further, as we see with the Joule Thief circuit, if you pulse the energy on and off fast enough so the human eye "thinks" it is on all the time you can use even less energy for the same light output.  Usually something above 60 hz or higher will work.
Off topic for here maybe but still a good way to use a lot less energy for the same light output.
Nice work,
Pirate88179
JuJu:
No, I am sorry that I do not know of any timing circuits that might work for you.  I have never played with anything other than the transistors we have been using....2N3904, TIP3055, and 2N3055. Our frequencies are usually up in the 25kHz area, or thereabouts.
Thank you for your kind words about my experiments.  I appreciate it.
flathunter
[A author=JuJu link=topic=7679.msg247093#msg247093 date=1277839346]
hmmm, as your are using a NST(i dont have one), just the MOT, so maybe in your setup the COIL can contribute to lower the voltage a little bit, and rise some current, thats why your load didnt show up without the coil. Because the NST will output high voltage but just a few miliAmps.
concerning the MOT... it allready outputs a considerable amount of current, thats why my setup will show the same effect onload, with or without the coil!
EDIT: if you have doubts in how to light an incandescent bulb with your NST ask user dragon, he is very kind guy, and putted is setup working with an NST!
hugs  ;)
[/quote]
I think you're mistaken.  The video i posted doesnt have an NST - just a 25kv power supply with very small amps, and lots of CFLs.  With this power supply i am unable to get a filament to do anything other than slightly glow even though the CFLs are fine.
I could easily get 3 filament bulbs to light with my NST (75W and two 40W).  I have a more powerful NST which im planning to test soon.  But I have no videos of my NST tests.
So...your Kapanadze works without the main coil....does kinda sound like the MOT is enough on its own then.  Can any other kapagen replicators try their load without the coil???  It would put a big question mark over the usefulness of the kapagen coil!!!
woopy
Hi acca
thanks for info
i have no problem with grounding.  By me if i measure the resistance between 2 rod (10 meter distance)  i have about 4 Kohms
I simply tested different grounding , (different distance between both ground, position and alignement , material of rod , deepness in the ground etc.. )
and i discovered that if i have a good ground after the load (bank of bulbs in my case) and only the ground plate under the MOT (of course connected to the secondary of the MOT) and if this plate is slightly over the ground with bad connection (some grass or other bad conductive material)  the plate was strongly and loudly arcing,       AS IF IT WAS A SECONDARY SG BETWEEN PLATE AND THE GROUND.      This arcing can be noticed outside the plate til 10 cm from the plate (the grass could fire from itself without any contact with the plate ).
And what about your very nice set up ,, did you already make some testing , any results ?
good night
Laurent
