0 Members and 167 Guests are viewing this topic.
flathunter
[A author=baroutologos link=topic=7679.msg247111#msg247111 date=1277846649]
Look instead of becoming fanatical about your new "invention" you should consider few things.
You are inexperienced. I know you from energetic.com forum posting a month ago what is electricity about.. Concerning my experimenting, you new here so you have not seen any i guess.
Learn that i look before i speak. And i have looked in your setup. Who told you in the analogue meter you had there, measuring the half wave rectified main's current that the 25w bulbs lights more than 6 watts???
[/quote]
I think you misunderstand juju's point - namely, that a bulb will appear ''well lit'' using only a very small amount of watts (10 percent of its rating).  He attempted to demonstrate this on his video.  I'm still a novice with a lot of this stuff, but i must admit i see no reason why jujus results may well be right.  Perhaps it is just the MOT being able to power the lot, with the coil just sitting there doing nothing...thats why JL Naudin is able to light 2200W of lamps with 200W.  I think juju probably came to this conclusion by disconnecting his kapacoil, and noticing that the load was still powered as before...but you'll have to ask him.
...i thought that you yourself suggested the MOT may be capable of doing this on its own when you first saw naudins setup?  Maybe im mistaken.
baroutologos
@Flathunter,
and you are right, that's the reason i urge anyone to have verified input and then output.
A 100% lit bulb to a 50% lit is 1/3 to 1/4 power difference.
Regarding juju' case,
Can he demonstrate to light the 100w bulb with 10w using analogue metering? ;)
EDIT: AT 10% common lamps are not well lit, but lit enough.
That's the reason people with Kapagen and variacs should check their load-banks directly from main and noticing perfomance at 80%, 60%, 50% 30% and 10% power levels. This requires some time to gain this experience.
grizli
Quote from: JuJu on June 29, 2010, 03:50:47 PM
bill, is naice to have your support, cause i admire very much your work, been folowing your videos from sometime ago!
no offtopic here, we are just trying to improve the concept...
do you have some inverter or timer circuit, that will work with my step down transformer  (I/P 220VAC 60HZ 0/P 10V 1A), im using it reversed as a step up.
in theory if i pulse 60HZ 10V at 1Amp at the primary, i should get 220VAC 45mA at the output... this way i will light the 100W bulb with just 10W... (instead of 13W using 91VDC)
and i can test another transformer that i have here... I/P 220VAC 60HZ O/P 9V 200mA, to see if i can light it with just (9Vx0.2A)  1.8Watts!
but i am not getting any sucess with the circuits that i have tryed.. :(
or maybe you can suggest a better idea? please you are free to purpose!
LOL
SORRY !
BUT!!
YOU get the same WRONG results cause of false measurements AGAINST OU, but other people get WRONG results cause false measurement FOR OU :D :D :D
YOU can not pulse and get GOOD measurements WITHOUT SCOPE !!!!!!!!
BOTH PRO OU and AGAINS OU people ...
;D ;D
grizli
Quote from: JuJu link=topic=7679.msg247108#msg247108 =1277846029
my goal is not to enhance power output, just lower it down! to prove that a lamp will light up with 10% of is rated input...
have you read all my posts? clogging this thread?
you are 100% sure, so... prove me that, just say WHY?, and HOW?
are you experimenting with the KAPAGEN? because i am, you have no proof to say that i am wrong, is only your assumptions!
so lets stick to the point, thats what im doing buddy!
im sick of theorizers, show us what you have, with proof supporting it!
this thing is full of fox mulders saying "i want to believe" ... without proving anything...
go one page back, and see my measuraments of current with an analogic AMP meter, and tell me whats wrong with it... im experimenting not telling what i believe!! wake up!
so whats the noob mistake?
ITS completely THE same if you use VARIAC and put 50V through bulb and measure current ad calculate power , or if you use pulse circuit .... filament is SLOW ans heavy you always have to look of AWERAGE  effective value of voltage and current for real meaurement...
just take variac and measure how much power is needed to make light bulb work
grizli
Quote from: dllabarre on June 29, 2010, 05:22:41 PM
:D  :D  :D  :D
I loved the X-files but you're correct.
Mulder never had the solid .
Don
NOR JuJu has SOLID Oscilloscope :D :D ;D ;D
