0 Members and 121 Guests are viewing this topic.
oscar
Quote from: electricme on July 08, 2009, 09:26:20 PM
Now, has anyone picked up a key element of this coil arrangement?
I posted back a bit about this but haven't seen a responce, so it seems it was missed.
There are a couple of frames at the end of one of the videos, I forget now which video it was, BUT this coil was being held UPSIDE DOWN.
I'm NOT going to tell you what I saw, (I have already done this in a previous post), rather I encourage you to go and take a look again yourselves. Its a KEY.
Attached is the simple screen grab (not enhanced).
How many coils are there (arranged inside each other)?
Only 2 (primary and secondary)?
Is the inner one wound conically i.e does it have a bigger diameter on the right (blue) side?
@Groundloop
when you wrote that you lit a LED from (the secondary of) your small Tesla coil,
- was there a spark gap involved?
- was one leg of the LED attached to the secondary?
- when there was not ground connection and the LED was less bright, was the second leg of the LED  not connected to anything?
(Maybe my questions don't make sense because I misunderstood something basic.)
The transmission was a '53 (Johnny Cash)
Groundloop
@oscar,
It was not a Tesla coil. There was inductive coupling between coils, NOT
resonance. Both my coils was connected together at the ground point.
The led was connected between this ground point and to earth ground.
The led was very dim when one end was not grounded to earth ground.
The led was bright when I grounded it. There was a 1mm spark gap used.
Edit: Connected like in the drawing.
Groundloop.
xenomorphlabs
Quote from: oscar on July 09, 2009, 09:27:03 AM
Russian forums confirm the observation that one coil is indeed wound conically.
You can also see on the pic that to tune the coil, the inventor has welded (tapped) the 6 turn secondary (its a downward transformer after all) maybe to find the resonance by "try and error" as had been suggested before.
There is many "keys" in that invention, one of them is certainly attributed to the thick welding leads, because the "Circuit B" is supposed to miraculously carry lots of amps, so the wire size needs to be chosen accordingly.
And "Circuit B" is the neckbreaker of that whole thing (Phase, frequency shifting etc.), "Circuit A" is 90% self-explanatory.
sterlinga
I've posted a feature page here: http://peswiki.com/index.php/Directory:Kapanadze_Free_Energy_Generator
Feel free to update, correct things.
Has the possibility of inductive coupling to grid power been ruled out?
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
ramset
Sterling,
This was one of the first things considered!
Chet
Thanks Grandma
