0 Members and 222 Guests are viewing this topic.
scratchrobot
The device looks simple but shouldn't the coils get tuned before expecting anything ???
scratchrobot
JuJu
my lamps are relatively bright with just arround 15% of the rated input so...
its possible that JNaudin is lightning is lamps with only 11.25W(each) X 16 = 180W (Input to MOT)
the only case that he will have full brightness in the load, is by climbing the input to values between 1000W/1600W
and then, tcharan!! 1600W output / full brightness, read dragon post!
Quote from: grizli on June 29, 2010, 08:22:42 PM
acording to google
It seems that half power roughly HALF brightness ... so... you are probably wrong, and if Naudin measurement is correct he brobably got some OU if we presume his bulbs glow realtivly bright
JuJu
good idea, here it is a simple resonance circuit calculator:
http://www.whatcircuits.com/lc-resonance-frequency-calculator/
Quote from: scratchrobot on June 29, 2010, 08:35:09 PM
scratchrobot
JuJu
if we are in a mood of reducing consumption, why not to reduce the input to 1W... then the extra 1watt FE should reveal himself! ;D
sory, just playing arround!
dllabarre
I ran my first test on my Kapagen replication.
I have a "kill-a-watt" power meter that I put in-line 30 feet before the Kapagen between extension cords to measure Watts, volts and amps.
1) tested 18 * 100 watt bulbs connected to MOT directly. 1043Watts. Bulbs fully bright
2) add MO capacitor.  785Watts.  Bulbs still fully bright.
3) add SG and 15kv Diode. 956Watts. Bulbs NOT fully bright.
Next step add coil and ground connections...
Don
