0 Members and 129 Guests are viewing this topic.
JuJu
Quote from: baroutologos on June 30, 2010, 04:33:10 AM
@JuJu
I have not formal EE training since Business Administration is my Degree. By the way, i read, compare and analyze what i see.
ps: My replication of Kapagen cannot start since i am locked in an apartment for now. August is near i guess for country side.
neither do i my friend, im just a Computer Technic and Dj!
look at the wonderfull video of mopozco! he is not using any ground and he still have the same effects, using a light dimmer as a variac!
hugs and sorry if i was rude! thank you for all
Quote from: Pirate88179 on June 30, 2010, 03:16:59 AM
This fellow has what appears to be a replication:
http://www.youtube.com/watch?v=vSxysPBvOu4&playnext_from=TL&videos=Z9_wO_KQx88&feature=sub
JuJu
any chance the system getting OU?
mopozco is proof that this thing will have the same effects, with, or without grounds!
im experimenting and i dont see OU effect, just very efficient way of driving lamps!
also dllbarre shared that is lamps are almost fully bright with just arround 50% input using just the MOT without grounds, SG or TC, and driving 18x100W=1800W lamps.
Quote from: bolt on June 30, 2010, 07:33:20 AM
Yes except he has linked his earth points up as a desk loop of wire and killed any chance of the system going OU. Nor will the center earth rod work which is why he can disconnect and remove it.
xenomorphlabs
Quote from: JuJu on June 30, 2010, 02:30:24 PM
im experimenting and i dont see OU effect, just verry efficient way of driving lamps!
Only if people get back to figuring out what Kapanadze really did.
His coil(s) looked different, his paths are different, his output frequency is 50 Hz.
Yet does he have 20 amps in the ground cable, which are either generated in the coil somehow or being pulled out of the ground. And that with a closed loop system with no wall or battery input.
JuJu
Quote from: xenomorphlabs on June 30, 2010, 02:50:53 PM
superb, as always!
exactly, if there was 20 amps circulating to the ground or even 5, my FAN will smoke... and it just spins at very low velocity (just a small amount of miliamps passing it)
in the kapagen patent the coil with more windings is not "directly" connected to the small winding coil but the small winding coil is connected to the supply and then to the large windings with some steps between that process, so there's not the "same" kind or amount of energy passing the 2 coils!
dont now if i expressed my self completely well, but i think that is understandable!
forest
Nobody is listening! >:(
Just test it the way I told you by cutting in the place described !
