0 Members and 100 Guests are viewing this topic.
bolt
Measuring the o/p is not required. Proof the lights are the same brightness as qualified by the lumen meter. Only require accurate power i/p readings using 500w-1000w inverter from car battery. If the results show 200w i/p to light 1200 watt lamps........ its mission accomplished.
aether22
I must say, I don't believe it is possible conventionally (without harnessing weird aetheric physics) to light an incandescent bulb in an incandescent manner (.vs gas discharge) with less current to the same brightness, it indeed violates ohms law.
But an additional test is to check it with a thermometer.
But since incandescent bulbs are simply pieces of wire heated by resistance to glowing, then switching to a heater will not change much as they are also resistive wires heated to glowing.
But really there are aetheric effects that could lead to the bulb being unusually cold.
The question is not if there is OU as that is clear (enough), the question is how can those of us with unsuccessful replications fix them?
It seems to me that those with successful replications should take parts out and switch things in a careful manner to rule out possibilities as to what is and is not key.
If this can be made properly replicatible, it's a new game!
baroutologos
@Aether,
You cannot say that OU is there. Progress so far is encouraging, but there is nothing definite.
Next thing Naudin should look is to rule out the possibility that Kapagen increases the Lumens/Watts efficiency of the bulbs that typically ranges from 3-4%. (thus not producing extra power)
Naudin is the most appropriate to do such tests.
FatBird
Some people here are really BLIND.  Let's put our thinking cap on here.
1.  Since the only power the Coils receive is through the Spark Gap, is it possible to Light Up 12 Bulbs without O/U being PRESENT?  The answer is of COURSE NOT.
2.  If you want further proof let's see you light up 12 Bulbs through the Spark Gap with NO COILS.
No offense, but come on now, let's open our eyes and WISE UP here!!!
xenomorphlabs
Quote from: FatBird on July 01, 2010, 07:44:52 AM
Some people here are really .  Let's put our thinking cap on here.
1.  Since the only power the Coils receive is through the Spark , is it possible to Light Up 12 Bulbs without O/U being PRESENT?  The answer is of COURSE NOT.
2.  If you want further proof let's see you light up 12 Bulbs through the Spark  with NO COILS.
Come on now, let's open our eyes and WISE UP here!!!
That depends on how you define OU.
Bedini has put it beautifully, he said nature might give us a quality of energy
that we might not need, because it is mostly electric power that people are after.
If the Kapagen maximizes thermal processes in the lamps that in turn increase the incandescence compared to a normal method of lighting them, then there is
a different kind of energy either being put in by nature (thermal energy) or maybe it is even no magic additional input , it is just a much more efficient way to make use of created HV current that we had to pay for.
It is obvious that this is a big achievment already. No doubt.
But to answer the question if the system indeed increases the electric power
in it (which most people mean with OU), can only be shown by looping it back or university lab electric power measurements.
