0 Members and 70 Guests are viewing this topic.
ramset
FatBird
Quote:
Come on now, let's open our eyes and WISE UP here!!!
AGREED!!
How to standardize successful replications should be a paramount concern!
Build sheet[material list] specs etc ....
Chet
PS XLabs
I'm sure putting a thermometer in his "black box" will suffice for comparison [heat].
Thanks Grandma
exnihiloest
Quote from: bolt on July 01, 2010, 06:14:49 AM
Measuring the o/p is not required. Proof the lights are the same brightness as qualified by the lumen meter.
presuming brightness depends only on power and is independent of temporal and spectral characteristics of the current (likely).
exnihiloest
Quote from: FatBird on July 01, 2010, 07:44:52 AM
2.  If you want further proof let's see you light up 12 Bulbs through the Spark Gap with NO COILS.
With no coils, or with the spark gap replaced by a contact, I observed the same brightness.
Nevertheless my coil was not built as every body built it here, so my experiment can't be conclusive.
bolt
As i have stated for many years now Radiant Energy is based upon PURE RF principles using standing waves as such a 1000 watt light bulb can be lit to full brightness using just 10 watts i/p power. The voltage across the bulb may only be 10 volts but the current maybe 100 amps out of phase. The VARS = 1000 watts in circulation. The bulb is lit directly within the element from radiant energy and NOT from the source supply. Conventional methods can not measure this power but eyes are the witness.
Same method as Tesla Hairpin and Gray under water lamp experiment.
For more backing watch Eric Dollard HAM radio vid on YT.
http://www.youtube.com/watch?v=YhuSn6sc7sc
He explains this is good detail as lamp is lit using longitudinal waves and electrons have NOTHING to do with electricity they are the waste product.
A 100 watt RF transmitter can be made OU using a VSWR ~ infinite. Earth plane using 3 ft wide copper plates.  Forces system into standing wave mode which is Scaler wave operation where RE enters the zero voltage nodes. Ground current runs into hundreds of amps while circulation energy is KVARS!
This transmitter transmits longitudinal waves and appears to a receiver as is if the transmitter is like a 100kw station yet it only requires 100 watts.
Radiant energy "gurus" like to make magic out of simple RF principles.
replicator
For more backing watch Eric Dollard  vid on YT.
A 100 watt RF  can be made OU using a VSWR ~ infinite. Earth plane using 3 ft wide copper plates.  Forces system into standing wave mode which is Scaler wave operation where RE enters the zero voltage nodes. Ground current runs into hundreds of amps while circulation energy is KVARS!
Radiant energy "gurus" like to make  out of simple RF principles.
Thanx bolt. I thought always this would be the way to achieve OU. Just check Tesla's notes you will find a lot of comment about standing waves as I remember. And maybe Moray used this also at his RE receiver (resistant loads only, good grounding always required and long wire antenna), never get 30kW of power from small radioactive parts without illnesses or huge degradation of parts.
The question is: how could we extract these energy?
