0 Members and 126 Guests are viewing this topic.
void109
In response to my earlier posts and replication failure, I believe I indeed had a faulty MOT.  I picked up another used MO, 1250W (with some really nice components inside! :D), and checking the L and R of the primary and secondary coils on the new MOT, the values are incredibly higher - my previous MOT must have been shorted somewhere in the coils.
Back to building for me!  (Oh and I picked up another 20 x 10A fuses to blow :D)
xenomorphlabs
Quote from: bolt on July 01, 2010, 08:57:12 AM
The voltage across the bulb may only be 10 volts but the current maybe 100 amps out of phase.
Not in Kapanadze´s system, he measures offscale voltages across one lamp upon making good contact. His meter can be assumed to be working alright because he can measure 220 Volt across the coil accurately.
I don´t understand what he said while doing the measurement, because he mumbles something in georgian language.
Maybe he just wanted to demonstrate that he can´t take an accurate measurement right at the bulb, which would be weird if he can take one at the coil.
bolt
Quote from: xenomorphlabs on July 01, 2010, 10:12:28 AM
Not in Kapanadze´s system, he measures offscale voltages across one lamp upon making good contact. His meter is working alright because he can measure 220 Volt across the coil accurately.
Yes of course you can have any mixture of VARS as standing wave component including high voltage and lower amps. Matters not so long as the source only sees  a very high impedance which means very little true watts required to drive the load.
Measure the power of a dipole antenna of a 4 watt CB radio at 27 mhz. On the edges of the dipole there is hundreds of  volts In the middle is hundreds of amps but between them the in phase power is only 4 watts. The radiation is pure Hertizian waves of instant loss.
Dr Stifler cold energy transmitter is NOTHING more then a standard wideband RF oscillator where the o/p is stuffed into an inductor to create a VSWR~ = scaler wave. This is why a neon on these o/p glows bright or scope shots see hundreds of volts on the antenna. The VSWR is TRASHED so source load is minimized. Radiant energy enters the system ONLY at nodes of standing waves thats why its called ZERO POINT ENERGY.
People like to think its something special when its just the same stuff "reinvented" and renamed as swamp gas or mystic ether flow, coherent energy, cold electricity its all BS to attract investors cash or make it sound like only somewhere with higher intellect could possible understand how it works.
Tesla power thru the air is nothing more then KVARS longitudinally wave transmitter where VSWR = ~
If you want to extract the power from Kapagen then use RF principles of series coupled transformer like IF radio transformer and match to load of the battery for volts and impedance matching using suitable tuned caps ready for looping.
Its no big deal to loop its been done many times.
flathunter
Nothing i like more than coming back from work, opening a beer, and reading what ive missed on OU.com (except building whats described) - great few pages!
@Fatbird - juju and exniholest both claim to have tried their MOTs without the kapagen and got the same effect as before with the load (i.d love to see a vid by the way guys...if you have the time....just disconnect the coil and demonstrate)
Can you try disconnecting your kapacoil and see if you get the same effect??
I was really pleased to see Naudins test...yep i agree only looping it will be definitive proof of OU, and that we HAVE TO be sceptics all the way, until we finish it.  Otherwise, how we gonna improve and enhance on our first prototypes without looking at things with a critical eye??   Great to see so many posters here using just such a ''critical eye'' in regards to every bit of news.  Its the only way we'll get there (and we WILL get there!)
Pep talk over - back to work!
e2matrix
<SNIP<
A 100 watt RF transmitter can be made OU using a VSWR ~ infinite. Earth plane using 3 ft wide copper plates.  Forces system into standing wave mode which is Scaler wave operation where RE enters the zero voltage nodes. Ground current runs into hundreds of amps while circulation energy is KVARS!
This transmitter transmits longitudinal waves and appears to a receiver as is if the transmitter is like a 100kw station yet it only requires 100 watts.
Radiant energy "gurus" like to make magic out of simple RF principles.
Being a HAM I understand VSWR fairly well but I'm not clear about what you are saying above in regards to "VSWR ~ infinite".  Do you mean the VSWR should be very high as in over 10000 to 1 or approach infinite?  Normally we want VSWR to be as low as possible i.e. say 1.2 to 1 to achieve maximum power output from a transmitter in HAM radio.  Is it the opposite that we seek for OU?
