0 Members and 207 Guests are viewing this topic.
baroutologos
Quote from: bolt on July 01, 2010, 08:57:12 AM
As i have stated for many years now Radiant Energy is based upon PURE RF principles using standing waves as such a 1000 watt light bulb can be lit to full brightness using just 10 watts i/p power....
I have heard you saying this a thousand times Bolt. Standing waves, nodes and antinodes for amperage, RF=radiant energy etc.
Firstly in resonators, the standing wave of voltage is apparent at discrete spots, called nodes and antinodes. A Tesla coil is an excellent way to demonstrate that.
But what about amperage? Who told you that amperage behaves as voltage in those conditions that means it formulates nodes and antinodes also? Any reason to believe that?
EDIT: if you feel so reply in PM so as not to bogus this site with less relevant info
bolt
Quote from: e2matrix on July 01, 2010, 01:58:25 PM
Being a HAM I understand VSWR fairly well but I'm not clear about what you are saying above in regards to "VSWR ~ infinite".  Do you mean the VSWR should be very high as in over 10000 to 1 or approach infinite?  Normally we want VSWR to be as low as possible i.e. say 1.2 to 1 to achieve maximum power output from a transmitter in HAM radio.  Is it the opposite that we seek for OU?
Basically YES. VSWR >10000:1   Watch the vids i gave the link in my last post. You will have to mod your TX no doubt to handle few hundred volts its difficult using fets better with tubes. Ground plane currents go ballistic hundreds even thousands of amps.
Don Smith was trying to explain this that in OU we seek VARS and KVARS not watts.  We are looking for trashed swr and do the opposite of what HAM text books tell you that you must NEVER do:)
In scaler operation drive requirements almost disappears allowing current and volts to climb to incredible values as electrostatic field. This violently disturbs the ether which attempts to CLOSE the field by pumping ambient energy into the system.
The antenna changes to an electrostatic mode of operation while your grid dip current drops to almost nothing.  Now your pumping longitudinal scaler  waves.
Now Don Smith  one to many coils operate in near infinite VSWR as TX while the RX's become magnetic copies WITHOUT loading the source.
People try to use conventional resonance logic to work out what frequency the coils operate at but in this mode the entire coil becomes ONE in electrostatic node. Only its overall length and width becomes a factor.
See Kapandze 100Kw free energy test.  3phase 1/4 wave driver into tesla tower as electrostatic TX operation then reverse process as RX to convert EHT back to regular 380v 3 phase. Not perfect match so i/p real watts still required as driver. You got to pay for something somewhere!
A 3 phase motor as Rotoverter operation can run in Scaler mode by creating a 3rd virtual phase where power factor is ZERO. (same as VSWR  ~)  In high impedance operation the internal VARS within motor windings will have many hundred volts and high amps.  As poly phase operation creates continuous leading power factor in resonance real ambient energy enters the system at zero point. Energy in this mode enters as spiral vortex is the basis of the TPU.
A large 5hp 3 phase motor will run easy on 12 watts RV mode as explained by Hector D Perez Torres for decades. It will piss over any bedini toys and charge 1000aH banks of batteries with ease. This is all open source for long time.
Kapagen coil in ideal conditions creates a VSWR ~ partial scaler wave operation where volts is pumped out of phase due to coil operates as electrostatic coupler NOT conventional resonance. Ground acts as capacitor supplies the amps. In this mode only pumped volts is required and very little current = low watts i/p.
Im happy people making kapagen just needs replication bugs to be ironed out.
xenomorphlabs
@Bolt:
So how exactly do you "trash" the SWR?
At what point do you collect the energy under what conditions?
Why did no replicator ever succeed that built coils a la D. Smith instructions just  caring for the coil dimensions?
bolt
"But what about amperage? Who told you that amperage behaves as voltage in those conditions that means it formulates nodes and antinodes also? Any reason to believe that?"
Dont lose track of what amps really are. Its WASTE. Voltage is potential joules while amps is the rate of dissipation  to total loss till you open the dipole back up again.
Take a look at your electric meter when running a massive inductive load then put a scope on see whats happening. Volts and amps become skewed out of phase till eventually current so lagged requires hundreds of amps peak to peak to catch the edge which is in phase enough to create the required watts. In this example you asked why amps can have nodes of high values. Of course! no reason you cant have 240 volts and 240 amps. PF 0 and you can measure both perfectly with  clamp amp meter and volt meter.
Bombay Electric don't want you to do this they say it puts heavy peak current load on system which is why factories must use PF correction.  "illegal" black boxes are just PF trash boxes to screw the meter. Most domestic meters cant read extreme lag or leading and they assume a tolerance somewhere close to 1.
bolt
Quote from: xenomorphlabs on July 01, 2010, 03:45:11 PM
@Bolt:
same way as you create a leading or lagging power factor on your electrical stuff. Use inductors or caps to give lagging or leading.
You have to match the load to the source using RF principles to maintain electrostatic resonance.
Don smith has been replicated thousand times. Its Tesla based stuff and kapandze 100kw is perfect clear example without any hidden green boxes.
Most people that made or own a Tesla coil think its only for making sparks. This is not the intended purpose its for making longitudinal waves and collecting radiant energy.
