0 Members and 213 Guests are viewing this topic.
forest
IMHO You have to do something to energy from LC circuit to change its form to electrostatic-longitudinal radiation and disturb ambient source.
Ambient source HAS TO be connected to OPEN circuit to catch electrons there and convert  into useful energy of HF current.
Like creating lightning.
bolt
Quote from: forest on July 01, 2010, 04:10:22 PM
Any idea how many volts with amps there are if you fly a metal foil balloon at 20,000ft and drop a wire down to ground?  Its hundreds of thousands of volts even on a clear sunny day with enough amps to vaporise the wire instantly.
There is no energy crisis never has been. Its like saying you are dying of thirst yet swimming in a clean fresh water lake.
God is either laughing his ass off or really pissed we are all so stupid to use oil and nuclear power.
flathunter
Quote from: bolt on July 01, 2010, 03:57:59 PM
Most people that made or own a Tesla coil think its only for making sparks. This is not the intended purpose its for making longitudinal waves and collecting radiant energy.
Any tips for modifying the tesla coil to collect some of this energy?
I was thinking of grounding both ends of the secondary 10m apart(top and bottom) and seeing if that did anything to my output (which is just a few filament lamps, but they light just as well as on my kapagen with the same NST)...will do it when the neighbours and the missus and the kids have gone out.
I'd like to understand better how this relates to tesla coils and standing waves.
replicator
Quote from: flathunter on July 01, 2010, 04:33:37 PM
Any tips for modifying the tesla  to collect some of this ?
Guys, let me summarize my observations.
Just like in a HAM TRX ( I am HAM also), the standing waves can destroy your power transistors at the PA, cos the amplitude of output voltage rise and add to the supply voltage on the collectors which overloads the transistor. But at that case THERE ARE NO OU just the output transistor pumped the wave and the next wave amplitude maximum added to the first one and so on...
In Kapa and Tesla case there are different thing but the basic principle the wave "pumping" creating high SWR on the wire. Hey, in Moray experiments, the observers only touched the end of antenna wire ,not near to the device and felt nothing, no shock no death, cos the maximum of amplitudes at the device side occurred!?
The Tesla's Hairpin circuit output lamp brightness is the maximum near to the basement capacitors of hairpin rods (check videos) and change almost nothing if the end is closed with a shunt cos at the end of hairpin twins there are amplitude walley.
Where is the tricks?
I think the whole phenomenon built up from multiple tricks. I try to summarize them below.
1.) The high VSWR is only one requirement to prevent radiation of energy to the environment but keep high level amplitudes at the wire. Moreover the device should put to the wave maximum (end of wire).
2.) The next one is to use open systems, where the second law of thermodynamics is not valid. To the open system the free electrons can be flow out and flow in.
3.) Pumping. Creating impulses via an asymmetrical SG would be nice to prevent the energy flow back to the source. I think to explore the phenomenon, not require MOT, high power, risky environment, It should appear at lower wattages.
4.) Need at least 2 different frequencies. A lower one and a higher one, the higher one sitting on the lower one by modulating it via AM.
The fifth point only theory, no observation:
5.) There are a very very interesting theory which based on electromagnetic equations and near field radiation. With many of small dipoles putting near each other can multiply the power in the near filed (it is too high for me, but I read...).
So I think the radiation line (antenna, ground line, 10m of Kapagen ,and so on) should be multiple the length of the higher frequency, so it will be a multi wavelength antenna from the viewpoint of the HF component.
But from the viewpoint of the lower component or pumping frequency this transmission line has a very high SWR ratio, so it should have the maximum of amplitude level at the generator side.
And the SG with the nonlinear characteristic itself can multi-modulate each other to aim higher level third (3rd) frequency or rise the level of the lowest one, or something.
Maybe the fifth point is speculation, the first four are the observations.
Sorry for this huge post (and my English).
grizli
Quote from: znel on June 30, 2010, 10:56:13 AM
We simply need to find the secret of exciting electrons with the smallest amount of energy possible.   Finding that secret is the goal of everyone here - "simply" in the statement above doesn't mean it's simple only that it is simply stated as the fact of finding it.  But... if we don't know what we're looking for how would it be possible to find it... ?
Its called resonator ...
Tesla quarter wve resonator  with thick wire and 1:2 čength to diameter ratio has the highest possible Q.. no energy lost  and amplification fastor at leat 10 000.. and requires PERFECT tuning
