0 Members and 144 Guests are viewing this topic.
grizli
Quote from: xenomorphlabs link=topic=7679.msg247268#msg247268 =1277923853
Only if people get back to figuring out what Kapanadze really did.
His coil(s) looked different, his paths are different, his output frequency is 50 Hz.
Yet does he have 20 amps in the ground cable, which are either generated in the coil somehow or being pulled out of the ground. And that with a closed loop system with no wall or battery input.
Ground is NOT battery....
FREE oscilatiing coil quarter wve resonance attached to ground pulls electrons at the bottom...
Tesla did simple and amazing experiment .. read coloradi spring notes..
His resonator is BIG coil and quality factor is at leat 10 000
In his experiemnt he connectd series of light bulbs to ground and other and to 1/4 wave resonator..
Transmitter WAS NOT CLASSIC TESLA coil.. it was just LC capacitor and inductor ONE END grounded...
6 turns of wire was L and C was about 150nF for about 100khz ...
at the bottom there could be 100A easily
grizli
Quote from: xenomorphlabs on June 30, 2010, 06:57:33 PM
Well then hopefully his next step is to attempt to close the loop.
Supposed that his input measurement is reliable, this is at least
a brilliant method to increase the light efficiency of lamps which can save
power for all those that use lamps alot and want to get more incandescence
out of them !
Tesla however noted this:
If he is right then the lamps have a much smaller resistance than being
calculated for, thereby also reducing the actual consumed power.
One has to keep in mind that the lamps in the Kapagen are being operated in an uncoventional fashion with high frequency currents.
Closing the loop will show ...
GAS discharge light method is 5-10 times more effective than filament bulbs .. so its correct..
CALORY METER is neded ...  get heater and put it to heat water ..
grizli
Quote from: bolt on July 01, 2010, 08:57:12 AM
As i have stated for many years now Radiant Energy is based upon PURE RF principles using standing waves as such a 1000 watt light bulb can be lit to full brightness using just 10 watts i/p power. The voltage across the bulb may only be 10 volts but the current maybe 100 amps out of phase. The VARS = 1000 watts in circulation. The bulb is lit directly within the element from radiant energy and NOT from the source supply. Conventional methods can not measure this power but eyes are the witness.
Same method as Tesla Hairpin and Gray under water lamp experiment.
For more backing watch Eric Dollard HAM radio vid on YT.
http://www.youtube.com/watch?v=YhuSn6sc7sc
He explains this is good detail as lamp is lit using longitudinal waves and electrons have NOTHING to do with electricity they are the waste product.
A 100 watt RF transmitter can be made OU using a VSWR ~ infinite. Earth plane using 3 ft wide copper plates.  Forces system into standing wave mode which is Scaler wave operation where RE enters the zero voltage nodes. Ground current runs into hundreds of amps while circulation energy is KVARS!
This transmitter transmits longitudinal waves and appears to a receiver as is if the transmitter is like a 100kw station yet it only requires 100 watts.
Radiant energy "gurus" like to make magic out of simple RF principles.
BUT BULB ITSELF is RESISTOR and votage and current ARE IN PHASE .. how can you put them out of phase !!!
so I agree , but its NOT classical VAR.. clasical reactive power CAN NOT do work on resistor... (its defined for reactive elements after all)
QuoteA 100 watt RF transmitter can be made OU using a VSWR ~ infinite. Earth plane using 3 ft wide copper plates.  Forces system into standing wave mode which is Scaler wave operation where RE enters the zero voltage nodes. Ground current runs into hundreds of amps while circulation energy is KVARS!
Whereis coil here ? ,,, but I agree Tesla calls that magnification factor
HIS BIG coil that has top voltage ONLY 500kV  has VAR energy of 4MW!!!!  VAR is realted to square of voltage  at the top of plate...
Experiemnt I mentioned before , Tesla says he could easily light up to 40 bulbs this way...  BUT resistance at the bottom must NOT be too high cause it will ruin magnifier effect...
grizli
Quote from: baroutologos on July 01, 2010, 02:37:20 PM
I have heard you  this a thousand times Bolt. Standing waves, nodes and antinodes for amperage, RF=radiant energy etc.
Firstly in resonators, the standing wave of voltage is apparent at discrete spots, called nodes and antinodes. A Tesla  is an excellent way to demonstrate that.
But what about amperage? Who told you that amperage behaves as voltage in those conditions that means it formulates nodes and antinodes also? Any reason to believe that?
EDIT: if you feel so reply in PM so as not to bogus this site with less relevant info
because it does ...
but you need coil that follows special dimmension ratios and perfect tuning...
1:1 coil make it behave closer to transmission line : you need precticly VERY VERY low capacity at the top of the coil , and also turns have to have at least gap the same as wire length ...
if at the top of the coil we have 500kV ocilating and 100khz of 20pF capacitor thats lets say 0.5*(500 000)*(500 000)*20*10exp-12=2.5J * 100 000 = 250 kW of energy oscilating at capacitor
At the bottom of coil is we PRESUME that RESISTANCE of coil wire = ZERO and that grounding resistance are also so good there should be E=L*I*I  . ,lets say we have 20mH coil and that  El=Ec  so current is 11A
possible mistake in calculations possible.. but I think (probably I am wrong) that was is here 11A*500kV=5.5MW....
Lets say we put resistor at the ground about 100ohm LOAD .. how will this affect whole system ..
I presume potential of bottom of the coil will rise but there will still be gread magnifiing factor ..
11A*100ohm = 12kW of energy that who knows where it originates .... if 11A still goes through LOAD .. there sould be 1095 V there ... this is small fraction  of TOP coil potenttial and probably will not affect the process
vince
Hi Guys;
Just wanted to show you my replication.  I was tired of blowing light bulbs so I am trying different types of loads.  This first test was first with one then two variable speed motors in parallel.  These are 90 volt DC, .3 amp 1/20 HP from gear drive units. These motors will run on 120 volt AC power at full speed.
With both grounds they both run near top speed.  After removing the ground from the center of the coil they still run the same.  It seems that on my unit the center ground makes little difference. I'm using a light dimmer switch to control the MOT, and it will adjust the amps that are feeding the MOT but it does not affect the RPM of the load motors. The spark gap is the only thing that affects RPM.
I've been trying to measure the input current to the MOT with a clamp meter and the best I could dial in with the gap and the dimmer switch was about 2.5 amps at 120 volts. A small gap with a continuous spark yields best results.
Going to try some different motors.
Vince
