0 Members and 144 Guests are viewing this topic.
stivep
THE NEXT VIDEO #11 SHOW EXPERIMENT WITH BULB DRIVEN BY THE COIL (TESLANDZE) AND SPARK GAP.
It is just preliminary video as for the first time I was able to get to this point.
But almost , at no time I have been able to start from nothing,advance myself to  laboratory, and get to the point I'm now.
I represent scientific approach to the subject of Free Energy  Tesla Based technology.
So please be patient the results have to be  properly investigated before it will be  given as factors, and/or properties.
Visual representation gives
You The Audience -
overall picture of where we are,and what we do.
http://www.youtube.com/watch?v=FcuINqlaH6w&feature=player_embedded
there are 11 video clips made by me the most interesting  start from video#7
Wesley
darkspeed
:P
ON A NEW CONNECTION FOR THE INDUCTION COIL  - 1871
By Prof. Edwin J. Houston.
The following experiments were made at the Central High School of Philadelphia, with the view of increasing the quantity of the spark of the induction coil without greatly diminishing its length. The instrument used was made by Eitchie, of Boston, and will throw the spark six inches in free air.
One of the poles or ends of the secondary wire was connected with the earth by a copper wire attached to a gas pipe. The other pole was connected with a wire, which rested on a large lecture table holding the coil. On turning the break piece, the electricity, instead of being lost by passing along the wires to the earth, jumped from the pole connected with the table, to that connected with the earth. The thickness of the spark was greatly increased, its length diminished, and its color changed to a silvery white, as when a Leyden jar is placed in the path of the discharge.
While the electricity is flowing between the points, long sparks may,be drawn from any part of the table, or from any metallic article within eight or nine feet of the coil. On one occasion the gas was lighted by a spark drawn from the finger of a person standing on the floor. The gas pipe being in almost perfect connection with the earth, the spark must have been given to it from the body of the person.
On another occasion one wire was attached to the gas pipe as before, and the other to a stove, whose pipe connects with that of another stove in an adjoining room. The thickness of the spark was greatly increased. Sparks were drawn from the distant stove, and even from a small steam engine, which latter was fully thirty feet from the coil. In all the experiments it was found necessary to insulate the handle of the break piece, as a slight shock was experienced at every break. The poles being kept at a distance from each other less than the insulating power of the coil, six inches, no danger of injuring the instrument was apprehended. In one instance sparks were drawn, in a room underneath the adjoining room, from a wire which connected with the table on which the coil rested.
These facts showing great loss of the electricity, but indicating the need for a large conductor, probably to allow the rapid discharge of the secondary wire, a large insulated conductor was extemporized by placing some old tin stills and percolators on large glass jars. On connecting one of the poles with this conductor, and the other with the gas pipe, the quantity of the spark was increased, though there was reason to believe that, with a larger conductor, better results would have been obtained. The conductor was then divided into two, of about equal size, which were connected with the poles. The quantity of the spark was increased, with, however, great diminution in the length. By successively diminishing the size of one of the conductors, and increasing that of the other, the length of the spark was increased, without any sensible diminution in its quantity, until, when one of the conductors was less than one square foot in surface, a fine quantity spark of about five inches was obtained.
It will be noticed that this connection is somewhat similar to that used in the common cylinder or plate machine, in which one of the conductors, generally the negative, is connected with the earth, and the quantity of the electricity thereby increased.
In all the experiments in which one pole was in partial connection with the earth, as when it rested on the table, the loss of electricity must have been very great, for several gas and water pipes are in connection with the table. If, then, the table merely serves as an imperfectly insulated conductor, which allows the rapid induction of electricity in the secondary wire by its rapid discharge, and thereby, notwithstanding the loss, gives so great an increase in the quantity of the spark, it would seem that if, instead of the table, an insulated conductor of very large surface were used, a much greater increase in quantity would be obtained.
It would seem from the above experiments that the maximum increase will be obtained when one of the poles is connected with an insulated conductor, say several hundred square feet in surface, and the other with the earth.
dllabarre
Quote from: hartiberlin on July 02, 2010, 03:31:20 PM
What will happen, if you put a bit of tap water
or saltwater into the sparkgap ?
Will this enhance the power output ?
Many thanks.
Regards, Stefan.
You mean to put some drops of water on the spark gap electrodes before I turn it on?
What will this do?
Don
dllabarre
Quote from: hartiberlin link=topic=7679.msg247567#msg247567 =1278099433
What could also be tried is an additional sparkgap at the primary of the
MOT transformer.
To have 2 sparkgaps in the circuit could still reduce the needed power input.
Regards, Stefan.
Not sure I follow you with this.
Do you mean to add a SG to one side of the Mains coming to the MOT primary?
Can you draw a schematic?
I'm not sure 120V alone will jump a SG.
Don
baroutologos
Hello Dllabarre,
So you verify also that a good two grounds connection is a must for good results?
I read that you used a N-S orientation for your electrodes. Perhaps you try to link Kapagen efficiency with Telluric currents? Good job.
If i may suggest, since the grounds are of importance, that you search, monitor and report if you can (and is not a fuss) the DC voltage difference between the two grounds due to Telluric currents, (Kapagen off) and correlate this with potential difference of Kapagen's Performance.
Just a theory, yet
