0 Members and 148 Guests are viewing this topic.
exnihiloest
Quote from: CTG Labs on July 03, 2010, 04:18:53 AM
http://jnaudin.free.fr/kapagen/kapagen33pio.htm
:( Upgraded power meter on the input now shows no OU...  Just a 96% eff...
Well, no OU. At least Jean-Louis is honnest enough to put forward a test that completely invalidate his previous measurement with the "Energy check 3000" (I said it before: "I'm not convinced it can give correct results with no sinusoidal currents and noisy HF signals"). But why not to withdraw his previous test or add a mention about its falseness?
Now we are left with two possibilities: either the Kapanadze device doesn't work or the Kapagen circuit is not the right schematics. In a first time, we should favor the second hypothetis.
So back to work and trials again...
Trastos
Quote from: Pirate88179 on July 03, 2010, 04:58:00 AM
96% still pretty good if you think about it.
Thanks,
Hello,
If Naudin has replicated correctly, Kapandze's only has a very effcient "High-Voltage Converter" for light bulbs?, however i think so that the Kapagen is a incomplete replication, because Naudin "only"  test the first part of the machine.  ::)
looked at from the positive side, we have more work! jajajajaja  ;D ;D ;D ;D ;D
In my case, im happy an if in my first step of Kapagen replication i had 96% of efficency.  ;D
dllabarre
Quote from: Pirate88179 on July 03, 2010, 02:08:50 AM
If anyone needs a chart to figure out the deviation for your location, let me know and I can post one.
I'd like the website to calculate the correct position of my ground rods.
I used to have it when I was working with Earth batteries but I can't find it.
It must be on an old computer.
Thanks
Don
exnihiloest
Any good transformer has more than 96% of efficency.
I don't see where is the exploit to connect lamps in series on the output of a transformer with 96% efficiency instead of putting them in parallel on the input with no transformer at all and 100% efficency.   :D
DreamThinkBuild
@All,
If anyone can run a arc lamp or other intense UV light from this, the next step would be to run a ring of high watt solar panels around the light.
