0 Members and 132 Guests are viewing this topic.
Pirate88179
@ All:
Let us not forget that Kapanadze closed the loop and his device was self-powered after being disconnected from the battery.  JLN has not done that as of yet.
What I am saying is just because this particular "replication" has not proved successful, we should not toss out Kapanadze's device along with it.
dllabarre
Quote from: baroutologos on July 03, 2010, 02:33:00 PM
Hey Don,
I have seen you have used a digital Power Meter for measuring your setup. Maybe its easy for you to check with this method http://www.overunity.com/index.php?topic=7679.msg246857#msg246857 the input amperage between mains/variac?
Just to be sure...
I don't have a variac.  My Mains is connected to the MOT primary through the watt meter.
The kill-a-watt meter I used acted "weird" when it was within 5 feet of my Kapagen.  Once I moved it 10 feet away it worked fine.  I then moved it 25 feet away just to be sure.
But people still don't believe....   :'(
I'll try measuring the amps using the bridge method.
How do you want me to measure the Mains volts?
My amp/volt meter can handle 20 amps and 1000 volts.
DonL
dllabarre
Quote from: Pirate88179 link=topic=7679.msg247711#msg247711 =1278182458
Don:
Here you go: http://www.ngdc.noaa.gov/geomagmodels/struts/igrfWmmZip;jsessionid=279A2514268729AB83FABE9F344671AE
Thank you.
But it's not what I thought it was going to be.
I thought there was a website that calculated how many more inches into the ground the North rod should be then the South rod?  Or how many degrees West the North or South rod should be from the other.
If I'm way off base here just tell me and I'll leave you alone.  :-\
DonL
baroutologos
Man, do not get this personal.
Its not about "people" wont believe. I want to think that they are not ill-intentioned people among us.
But working on such field we must enforce a kind of measurment techniques. Many suggested require to be skilled etc (as a oscope for identfying pattern etc).
Its not about to use the method suggested . You can invent your own, (use your creativity regarding output) but every one of us must eliminate some problems repeatedly reported as a digital meter in RF enviroment etc.
See how Naudin fooled himself on that.
JuJu
dlbarre i agree, this is a very efficient way of driving lamps, that can cut our lamp bills in maybe an half? is a good discovery, that can also save hundreds and hundreds of tons of pullution, if you can make a SG that will last for lon times, but not OU!
Quote from: baroutologos on July 03, 2010, 03:10:53 PM
not just himself, but almost everyone arround here! everybody was allready making lots of theorys of pulling electrons, bla bla... thats the difference between talking and trying it!
lets keep our feets on the ground for the next time pleae, before we take conclusions in advance!
hugs
