0 Members and 121 Guests are viewing this topic.
Pirate88179
Quote from: dllabarre on July 03, 2010, 03:06:49 PM
Thank you.
But it's not what I thought it was going to be.
I thought there was a website that calculated how many more inches into the ground the North rod should be then the South rod?  Or how many degrees West the North or South rod should be from the other.
If I'm way off base here just tell me and I'll leave you alone.  :-\
DonL
Yes, this is the site I used as did a lot of others.  First, you plug in your exact location on the planet, then you can select everything you want to know about it like deviation and declination.  It also shows the dip angle for your area which is what you need to calculate the angle for the bottoms of the electrodes with the north (plus) being the deepest.
The only thing I think might be important here with the ground rods is the distance between them and their polar alignment which my guess would be north/south along the meridian and not magnetic n/s.
dllabarre
Quote from: baroutologos on July 03, 2010, 03:10:53 PM
Man, do not get this personal.
Its not about "people" wont believe. I want to think that they are not ill-intentioned people among us.
But working on such field we must enforce a kind of measurment techniques. Many suggested require to be skilled etc (as a oscope for identfying pattern etc).
Its not about to use the method suggested . You can invent your own, (use your creativity regarding output) but every one of us must eliminate some problems repeatedly reported as a digital meter in RF enviroment etc.
See how Naudin fooled himself on that.
It's not personal.  >:( Dam it...  Just kidding...  :D
I'm not an EE.
Just tell me how to measure the Mains input Amps and Volts so that everyone reading this will accept the results.  That's all.
If you're not the correct person to tell me how to do this then someone please come forward.
I want to move on to figuring out what part of this device is giving me the extra power.  But before I break it I want to satisfy everyones doubts.
Thank you.
DonL
PS - I can't stand all these highlighted words.  How can I turn that off?
dllabarre
Quote from: Pirate88179 on July 03, 2010, 04:00:47 PM
Perfect!  Thank you.
I figure, might as well make everything with the ground rods as perfect as I can.  Orientation to magnetic North, depth, etc.  Being the ground rod modifications helped me lower my input power I wanted to throw in everything I could.
Again, Thank you.
DonL
bolt
"Just tell me how to measure the Mains input Amps and Volts so that everyone reading this will accept the results.  That's all."
There is only ONE way to be sure of true i/p power readings. If Naudin had done this on day one as  i been calling on anyone that thought they had OU. This would have saved everyone a lot of grief.
As now proven (yet again) killawatt meters tell lies under adverse conditions!!!
USE AN INVERTER AND MEASURE THE BATTERY DC I/P VOLTS AND AMPS.
forest
Quote from: bolt on July 03, 2010, 04:42:28 PM
Yes. +1 vote
