0 Members and 194 Guests are viewing this topic.
forest
300W inverter would be enough to proof OU, just start with parallel power grid then limit input current to 200W as per previous Naudin videos and switch to only inverter.
Is that possible ?
FatBird
@ Pirate88179
Yes, that would be correct.  Just not the north your compass points to.  That can be off many, many degrees depending upon your position on the planet.
BRILLIANT IDEA having them try different Coil Positions to Maximize Output.  I read that Dr Aspen & others say that a Coil will deliver MORE OUTPUT when pointing a certain direction.
bolt
Quote from: forest on July 04, 2010, 06:30:41 AM
Is that possible ?
You need 500-1000 watt inverter as many MOT need a powerful kick to get them started and running to generate a spark. A small inverter like 250 watt will stall and the MOT wont even start before the inverter shuts down and  or blows a fuse. Inverters are cheap you can buy them off ebay for a few bucks AND if you are thinking about looping anything you will almost always need a battery plus inverter!
Once at DC level to a car battery measure the DC volts and the DC amps MINUS idle running watts of inverter = TRUE watts required to run system.
This setup is validation used for hundreds of other OU tests where the mains and AC gets screwed up and need ACCURATE method to measure power consumption.
FatBird
@ Bolt,
Excellent points & procedure on how to loop everything to measure the Input & Output Power & ascertain the COP.
JuJu
conspiracy theory? oh dam, he wants the device just for himself  :P
Quote from: grizli on July 03, 2010, 06:49:58 PM
hehe .,,what if Naudin made deliberate "NOT OU" results ?
