0 Members and 194 Guests are viewing this topic.
kukulcangod
Folks
        I've been studying about don l smith for a while and with all due respect to mr naudin whom I've been following for years, this kapagen has a very different simpler configuration than the one called in the kapanatze patent or in comparison with the don l smith patent , there are 5 videos of don l smith explaining how to make this devices and if about making something we should follow his advice for it is clearer than the one from kapanatze by far, smith even gives away a small device that doesn't need tunning, all that discussion about inverters capacitors ground etc have been already mentioned by smith, I'm in a foreign land right now where it is utterly dangerous to create this devices in case they might fall in the wrong hands, I rely like pirate said on observation right now coming mainly from smart folks like you, and for it I'm very grateful, so this are my 5 cents rigth now. I'm interested in another device of my own but I still don't have a prototype and that's gettinng my attention this days, I would if time and location permited build the smith device, and yes of course nothing is completely clear and for that reason as experimenters builders we must attack the problem of filling in the blanks, I do believe this is real and is possible, mr naudin is giving us a very valuable start up, see? we see the water from many feet above and it is cold we think to jump into it too much! ... And he just do jump!! . Money for my project is limiting resources for the small not tunable device that smith recomends to build to start, one thing i did observed about this radiant energy is that the correct capacitor is needed to used it, few farads , fast that is and to the transformer, from there, is regular business given that we got the rigth LC calculations to run our devices, given that we have tuned up correctly to our particular environment like smith says is different for every location not to dramatic it means you can get more or less energy, but in some extremes nothing until everything is tuned up, when tunning is needed remember that moving those 6 turns inside the longer one with more turns will give more voltage or amperage, as you can see there are many things to consider before geting something going on, my device is not that complicated and about to adapt it to work with high frequencies. The way I came across the radiant effect was by pulsing dispossable camera capacitors voltage goes way high then again it has to be at high frequencies and permanent in order to be able to stimulate a transformer and then used to charge batteries and operate machinery continously according to proportion.
I want to share something about resonance, there i was studyin hard to understand it better and like the proverbial thinker, the answer came to me in a bathub!! I was taking a shower with my new massaging shower head , then again a funny rythmic noise came from the thing and at some point regulating up and regulating the faucet below I was able to change the pulse or frequency of the darn thing because it was never to my liking, then at moments I heard a loud sound between the walls , i was in a second floor, I found that way that the water tubing was shaking! I did fiddle with the shower settings until I sustained the water pipes moving in synchrony with the shower head massage settings!! resonance!! the sound became very loud in and ever increasing pattern!! I heard my neighboors downstairs getting alarmed asking what was going on! ....I had to stop my experimenting, because we had a rupture very difficult to identify in origin and pooring through their bathroom staining their ceiling etc ..A mess ... So I stopped torturing them(they used to complain for anything anyways) but the sound was dramatic the vibration shaked those pipes as if they were angry snakes inside the hollow walls!!, after that I modified the shower head by taking the suppressor inside it letting more water pass without too much pressure and that was enough to confuse the landlord and the plumber!! they never new what caused the problem really, they just changed everything just in case, after that no matter what I did conditions were not met to cause a dramatic effect once again....See ? it was by a chance... Myth busters whom I hate with passion tried, at a bridge getting results but they always do things half way(remember what they did with the Bedini generator) so take it as just a weak example of what all of this means...
Cheers
baroutologos
Why it is so difficult to spot an OU procedure? (maybe chemical, mechanical, electrical, nuclear, magnetic etc)  ???
aether22
Quote from: Groundloop on July 02, 2010, 09:25:16 AM
@aether22,
Great test. :-)
The plasma ball oscillator will survive 6 volt so if you have a 6 volt
battery then you are good to go. Just remember to put a heat sink
on the plasma ball oscillator.
A neon bulb is normally 65 volt on. It will stay on until the voltage
drops below minimum on voltage around 50 volt or so.
Groundloop.
Good Idea! (obvious but I didn't consider it)
The one I used differed to yours though, but now you have said this I can go out, buy another rather than trying to figure out how to build one.
I did try yesterday to get it to work with a big 50hz Neon Sign Transformer (NST) but while it seemed to work it also changed the tone of the spark gap when the connection was made, I realized that I was creating a capacitor between the 2 coils and that was changing operation and the true reason for the light glowing brighter, when I switched the connecting wire to the other side of the SG to remove the capacitance effect it didn't glow brighter when connecting it to the the bulb.
I am now really glad that with the plasma globe power supply it worked when connected to the coil side of the spark gap because if it was only the other side (which I guess due to the mass of my secondary coil swamped it killing the gap) then it could simply be the change in capacity, but that is not it!
So, off to get another Plasma Globe, good thing as I hate building stuff with IC's and transistors etc...
BTW, I think JLN is lying about his power, I think he was scared off.
Lutherg
Quote from: grizli on July 03, 2010, 06:49:58 PM
hehe .,,what if Naudin made deliberate "NOT OU" results ?
Did anyone notice the chart Naudin first displays at exactly 3:10 in this video:
http://www.youtube.com/watch?v=c99UEvpZp8M
regards,
Luther
aether22
Oh, I should add, I found one curious setup...
I had the NST (with a variac dropping the voltage in heavily) going to a spark gap, if I connected the many turn coil of my Kapagen to either end of this spark gap, the unconnected fat wire 6 turn coil connected to the 12v 100ma light would glow.
This is interesting since only one side of the secondary was even connected, and it was connected to an NST shorting through a spark gap.
Even more interesting since the spark gap wasn't designed to create oscillations and it runs at 50hz so it's weirder than if this were happening with high frequency.
