0 Members and 1047 Guests are viewing this topic.
exnihiloest
Quote from: flathunter on July 08, 2010, 01:59:48 AM
JuJu and you and dllbarre and a few others (mopozco) immediately replicated Naudins kapagen and demonstrated the error in various ways.  Now we all know better - Thanks Guys!
Well you are very positive and optimistic.
For me this step was useless and I still ask me how (or why) JLN, who has intellectual capacity, knowledge and test equipment, missed this big hole in his measurement process and made a premature announcement.
Let that be a lesson and let's turn the page.
exnihiloest
Quote from: nievesoliveras on July 07, 2010, 05:30:11 PM
Maybe this has been seen already and after kapagen who cares. But maybe it is still important.
Jesus
Hi Jesus
I looked at your electric diagram. The output circuit is closed with two ground connections. The inductance of the tank circuit with the "20 mkF" capacitor is coupled to a coil powering the load. It is the same as the kapagen except that the load get current not directly but through a transformer. So I don't think it is an interesting way.
If we want to move forward Kapanadze's device, we must keep only one ground connection and prove that this ground connection has a real effect on the functioning.
Even though there was not OU, such an effect would be revolutionary because from a conventional viewpoint, currents and voltages in a closed circuit doesn't depend on the potential relative to the earth (presuming there is no experimental error such a current leakage from the mains to the earth through the system).
May be we could connect the ground through a big inductance and obtain a open LC circuit, C being the earth capacity. Due to the earth resistance, only a small portion of ground around the connection could act as a charges reservoir. Thus I suppose C is weak and either we have to use a very big inductance or to add another capacity in parallel with the inductance to tune the circuit. We also must keep in mind that such a system will surely couple to the mains through the MOT parasitic capacities. Great precautions should be taken to avoid experimental artifacts. I will try when time permits.
baroutologos
@Exo,
I have been saying the same for more than 10 posts.
What schematic do you really suggest?
JuJu
lol, if you think that of Naudin, and if it really happened why you choose to folow his experiments this time?
i sayd allready, folow yourself or folow the others! if  you choose to folow the others even after your opinion of them its not reliable, then that is not the others "fault", but your fault!
Quote from: exnihiloest on July 08, 2010, 03:30:18 AM
Sure. For example he is the only one to have seen OU in the MEG. Hundreds of people tried to duplicate it in vain. Even Bearden did not build successfully what he theorized!
You are right. Nevertheless please note that we are in a thread entitled "Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze" and most of people speak about kapagen of JLN (me too, I confess). So it is not a simple question of to follow or not. Even if you don't want to follow, any subject that you are involved in, is more or less polluted and this is a real waste of time.
