0 Members and 1047 Guests are viewing this topic.
JuJu
@ALL
I made a video using an 150W (300W peak output) 12V to 220V Inverter, i was hopping to light 300W lamp bank, but this cheap crap dont even can light a 60W bulb without starting to bip, to bad... i still made the video because there's some interesting observations that we can clearly see in my setup!
Combinations:
Just MOT - good
MOT with Coil - better
MOT with SG - even better
MOT with COIL + SG - the worst
its possible that a SG can damge ampmeters? mine started to work in reverse when i connected the SG and i think its not reading accurate now, have to make more tests...
almost all the video im using just the mot and conducing experiments with each component, at the end i try the coil with other combinations! the lamps are 25W! take your own conclusions!
Enjoy! http://www.youtube.com/watch?v=LXylTPZ4BS8
;D
baroutologos
@Acca,
Well-said. Really.
The problem is, that there have not been an OU machine invtentor's seminar that provided any short of specific guidelines, only theories and perhaps an OU model running under mysterious cirumstances, not allowing anyone to get a hold of it...
Most of their theories pronounced (99.9%) have been found completely untrue, and when anyone does some basic experimenting understands those fallacies.
When a group of people willing to make such a device comes together, and upon encountering the problem of making this device to go OU (it is supposed to face that problem since OU is supposed not to be real) and are turned to inventor for know-how, he usually (if he is allive) reply in riddles, chinese wisdom etc (I know what i say!)
In case the inventor is dead we are found in situations that there is not a document left, how he made any of his devices only a patent at best and few general words.
I do not want to go in detail. You mention that people will make the coils smaller/larger, will mess the circuit etc. What you fail to grasp is that NO-ONES have provided any OU principle of operation, that has been tested with plain means and found true. (no need to construct a fine tuned, looped OU mdoel)
I explain:
Modern electric motors are sophisticated pieces of equipment and if i ask someone to construct one of them is almost impossible. But, the principle of operation can be immedietely seen by having a wire going via two magnets and when applying to it electricity, the wire deviates. This is the principle.
Modern sophisticated internal combustion engine, (high tech) rellies upon the principle that during a gas' combustion their is an expansion by heat of the product gasses.
etc.
Have you read, anyone in the vast FE literature, (irrespectively of their setup machines) provided any Principle of work that takes 1 joule of energy and outputs 10 or 100 or 1000, and proven true?
exnihiloest
Quote from: dllabarre on July 08, 2010, 01:48:00 PM
My actual watts used are lower when measuring with analog meters compared to the Kill-A-Watt meter.
Hi DonL
You can't expect for accurate measures if your analog wattmeter includes diodes or rectifiers, because of HF noise.
A true and accurate analog powermeter is only a thermal wattmeter, using thermocouples and permitting measures on a very wide band from DC to hundreds of Mhz.
See a modern design here: http://www.yokogawa.com/tm/tutorial/tm-tutorial_wt_12.htm
So far Kapanadez's device falls in with all the other devices where the developer won't give out details for replication and no one has totally replicated it.  SR only lights 1 bulb so he is close but no cigar.
Kapanadze's device is really poorly described in the patent, with black boxes named "frequency stabilizer" and "frequency adjuster". This is obvious and I don't understand that it has been accepted.
But on the video, Kapanadze is using only one ground connection. All replications with two ground connections, which have a key role in closing the circuit, are therefore not relevant.
baroutologos
Hi DonL
Hey exo,
You are right about exact figures measuring. But the FWBR method and analogue metering gives you a damn reliable picture of input.
What about the HF in diodes? Have you tested how normal diodes handle HF?
I have tested in my Kacher the 6A10 diodes, which work (the Kacher) normaly at 500Khz or so. IMO HF is not such trouble as either is rectified by diodes or blocked (since cannot respond that fast).
After all, if his wattmeter gives same results as the analogue means , chances are to measure it correctly in the first place. As woopi's FWBR-ammeter and clamp meter. (few RF all things could withstand.)
ps: I will arrange a series of experiments as FWBR, analogue meter and a load to work in my Kacher (400-600Khz) just to see it experimentally what i say. Photos etc next week.
flathunter
Quote from: xenomorphlabs on July 08, 2010, 11:50:52 PM
Without going nuts on this, but again Kapanadze NEVER published any detailed circuit schematic. The schematic you are referring to has been made by Alexander Frolov and is merely an attempt to explain what is going on.
It does not take into account a couple of things that are present in Kapandze´s device ...
Hi xeno!
Sorry for the of topic request, but i remember that you know Russian, and the Russian forums, very well.  Do you know of some basic intructions for building a ''kacher'' or ''Brovin Generator''??  I know Juju and dlbarre are also interested, and there have been some very interesting videos showing 15W bulbs lighting on 8V and 120ma.  We could start a new thread (maybe there is an old one, but i havent seen any here) if people like, but i reckon its connected to Kapanadze and could help us along the way with some simple targets - smallest battery, biggest lamps kinda thing.
Thanks in advance, and good luck!
