0 Members and 586 Guests are viewing this topic.
FatBird
@ dllabarre
Thank you for sharing your GREAT photos.  We really appreciate it.
JuJu
@dlbarre and all
you r right about the spark gap, and the 2 grounds! in my case it works much worst because my coil should be resized to this smaller scale! im using comon ground and i can see some more power when the coil and mot are connected to common grounds, but somehow the SG mess with the coil, because is not matching the impedeance, voltage needed, etc
one doubt, when you do half rectify to dc, the amperage should drop in half also as voltage?
i measured the voltage across the lamp and it can reach near 200VAC in the short pulses, 200V x 0.1A = 20W (my ampmeter shows 50miliA in the peaks - half dc)
i dont know the power that the MOT alone needs to sustain in open circuit? but the inverter needs 12V x 0.4 = 4.8Watt
What is very strange is that when the inverter is charging energy to send the peak output, the meter is bouncing and it drops in short cycles to 320mA with MOT and Lamp load?
I noticed that the peak is near 1.3, 1.4Amps, but the values differ in accord with the components used, and can reach 2.1 Amps at most.
so based on the efficient setup, 0.4Amps goes to the inverter, and 12V X 1Amp = 12W goes to the load...
12W consumption VS 20W load (if my output calculations are right, maybe not?!) is something to investigate... someone have a 500W or 1000W inverter, we should measure this connected with just one ground and coil, without SG so there's not RF to mess with our meters!
dlbarre is right in someway... probably there's is nothing about the Kapagen, but maybe there is something about the MOT / High Voltages transformation, and the Coil, SG and ground if fine tunned can help!
im preparing my video on transformers, experimenting all kinds of toys, regular step up, one to one, my own made, some flybacks.. all with scope readings, lot of fun!
BOOOOM
baroutologos
Hi baroutologos
We need another pole acting as a charge reservoir, electrically isolated from the first one in order the charges can oscillate between both poles without electrical conduction, may be a high Q LC tank circuit thus able to store a lot of oscillating charges...
I have calculated in order to achieve from ground to "device" and vice versa current movement of 20amps (as per Kapanadze) at 50Hz, you gonna need that "charge storage" of some 500uf value!
One terminal capacitance of such huge value is inconceivable for me right now... :(
What I said is based on a long experience in HF. I don't affirm that measurements are always bad with HF but possibly, so we have to be careful.
True, always the potential of error due to HF is there. But with analogue means etc is greatly reduced. A battery-inverter input setup is the best way to know.
@Flathunter,
I was taught to make Kachers from Destine. The ones built by me have been made per destine specs as Xeno's link. (lastly a made a small one with fewer turns wire and a ferrite core inside it) I have seen many you tube videos and claims that Kachers can go OU easily. Not my experience. Most of people (99,9%) who have made Kachers would say it is a very nice HF oscillator, but not an OU device. Mine draws at full input some 100watts to light a bulb at best to 40% eff.
Its an elementary funny thing, quite useful for understanding HF electricity' behaviour.
exnihiloest
Quote from: Acca on July 09, 2010, 01:34:03 AM
It takes "VERY HARD WORK" to understand and LEARN
If you are crying that it doesn't work, it's because you DID NOT SPEND ENOUGH FREE TIME TO LEARN AND BUILD devices
What you suggest is: "there is a theory because someone claimed it (call it "OU" or whatever else), therefore if you don't observe anything in your experiments, the reason is that you didn't learn or did not work enough"   :-\
It is not this way things go in science.
At the begining there are recurrent facts or reproducible observations. If something new is going on, a question arises: how? The answer to "how" gives a theory that modelizes the observations.
In Kapanadze's device and in all other so-called OU devices, there is a lack of facts and observations. The main reason is deficient descriptions (for example what means "frequency stabilizer or filter" in Kapanadze's patent? How is it built?).
But even when there is a detailed description, the blind believers accuse every builder of unsuccessful duplications of not having done the right things and of not being serious, instead of accusing the "inventor" of making inadequat descriptions, mistakes or trickeries and being a nut case or a con man.
nievesoliveras
Hi!
Maybe somebody has the same problem.
First my computer adquired a virus named win32 that damaged all my executables, even the operating system.
I lost most of my valuable information and what was left is mostly incomplete.
Now the problem is when I am trying to reply to someone on this forum.
The screen where you supose to write your reply begins to scroll up and do not let you see what you are writing.
Is it only me or does somebody has the same problem?
Jesus
