0 Members and 243 Guests are viewing this topic.
Gobaga
Quote from: cosmoLV on June 25, 2010, 08:13:59 PM
i don`t understand relationship between Tariel Kapanadze and kapagen - these are two different things!!!
One are based on Nuclear Reactive Ferromagnetic Fields and other like Naudin is based on HV transformation and nothing to do With FE - i don`t understand this!  This is wrong thread and Kapanadze are nothing to do with Naudin...
Absolutely.  It is about time someone pointed out the erronious copies of Kapanadze device.
I read your posts on Energetic Forum - very interesting.
Have you actually built the transformer with a ferrite core?
dllabarre
Quote from: bolt on July 14, 2010, 10:44:37 AM
This will give you an idea. My circuit is to show how to run a 3 phase motor in RV self sync mode using extreme VARS will attract loads of Radiant energy. Its also the basis of the TPU just replace motor coils with 3 TPU collectors will create rotational magnetic field self spinning. Look carefully at battery current and tank VARS. It runs with gain!
Thank you.
Clarification:  (can't read all part sizes)
The resistor on top - what is the size of it?  Just says 1.
What Transistor do you recommend?
The cap in the middle says 7uF is that correct or should it be 47uF?
DonL
bolt
Quote from: dllabarre on July 14, 2010, 12:08:13 PM
Thank you.
DonL
cap across the coils is 7uf gives a frequency of around 80Hz suitable for running a 3 phase 5HP motor on less then 10 watts.
The 1 ohm resistor is my current shunt to measure the circuit amps. You can omit this if you want. The power FET is anything meaty like 600-1000 volt 10 amps or whatever you have to hand. Be aware the tank VARS is huge and the fet needs to handle this. For TPU operation you just make any collectors you like using 4 to 6 turns of lamp wire per collector then tune the 7uf cap will be replaced with like 0.001uf 2000v working and around 100kz on the coils then hope your TPU dont go over and blow it. As SM said the TPU runs with gain and destroying fets is a daily hazard when using scaler waves. This is why SM used a mag amp in place of a fet. He NEVER banged his coils with POWER FETS for a start they were only just born in the late 80's when he made his first tpu.
dole
Hi,
We all like excitements so do I :) but it will take a time to solve the puzzle :(. Does anybody know (see) what is happening when two standing wave proper cancel each other?
@bolt
Something like that? Cold spark gap:
http://www.youtube.com/watch?v=OGkZIx4rseE
I can describe this later or may not be necessary, no burns, no injury but nothing new, just proper adjustment … Tesla :)
d.
bolt
Quote from: dole on July 14, 2010, 12:43:35 PM
Hi,
@bolt
d.
Yes he knows how to do it too but i already explained how.  Also its harder to find zero point nodes on a single phase circuit tuning is a bitch require critical mindset of a seasoned RF engineer MUCH easier to use 3 phase pumps.
But if you tune it very carefully you can run a 1000 watt lamp on radiant energy from within an LC circuit where the lamp in series with L and C tuned to create perfect out of phase signal.  I might post you a little schematic later showing how properly to use a spark gap into a tuned tank.
