0 Members and 537 Guests are viewing this topic.
sparks
     If you expend 4kilowatt hours of electricity in doing work.  This work is transferring charge to a capacitor say at a 90 percent efficiency.  You will have 3.6 KWH of potential work stored in the charged capacitor.  Now if you discharge this capacitor into a dead short over the course of one millisecond.  Your 3.6kw becomes a 3.6 billion watt transfer of energy from point a to point b.  This type of change in the ambient field is sure as the sun is hot going to disrupt life as usual in and about the planet.  By his own admission Tesla feared shorting out his magnifying transmitter.  When people finally figured out what this man was up to and the reprocussions of the device failing they kinda put him on a short leash.  He had a resonant tuned device that could easily store not just 4kw for an hour but everything the local grid transformers could feed into the device.  That would be in the thousands of kva input for goodness knows how long it took to ring this thing up to operating levels.  And everybody wonders why they shut Wardenclyffe down.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
From this video it is clear to me that's transmitter and receiver, while receiver is Tesla coil where secondary is thick copper pipe.Bulbs are connected from ground water pipe to the upper end of copper pipe-secondary.
I'm interested in finding what is connected to the lower end of copper pipe -secondary , but it may be just floating in air.
ramset
bolt
You spoke of a "mentor".
Can you suggest any reading ?
Thanks
Chet
HMmmm
We Don't all have the ability or the equipment  to contribute to the progress here.
but that can change VERY fast with a little better understanding !
Thanks Grandma
bolt
Quote from: ramset on July 15, 2010, 04:25:49 AM
bolt
Thanks
Chet
HMmmm
Its called Google! But with 2500 post under your belt you should have worked out by now the methods required to extract ambient energy. Pretty sure you don't need a mentor. Its really no big deal we are an iron ball floating thru space covered in tetra-watts of free juice. God made the earth and all of us and on the 7th day he gave us free electric:)
All you have to do is give it a little stir and collect it.
Drop a copper wire off a balloon from 20,000 ft,  at the ground it will have a PD of thousand of volts and amps. Even rescue helicopters have to "short out" to prevent killing someone with this power... Yet some say "oh i think free energy is BS"
telluric42
Hi all :D
i have a question for the tech's of the group......please keep it simple i'm a newbie ;)
most of the coils that are on Kapanadze replications are bigger (longer) than the original.......why is that?..........has anyone tried to copy his design as close as possible?
thanks heaps :D
T42
