0 Members and 296 Guests are viewing this topic.
ramset
bolt
quote:
Its called Google! But with 2500 post under your belt you should have worked out by now the methods required to extract ambient energy. Pretty sure you don't need a mentor.
No, I think I need a live in mentor!
2500 posts and still clueless [well I do have theories]
Do I get an A for effort?
To be honest, your in sites make a lot of seance , That is why I asked the mentor question.
and this guy does over unity at will, but he ain't talkin!
http://www.youtube.com/watch?v=eKPrGxB1Kzc
Chet
Ps
I appreciate your contributions tremendously!
Thanks Grandma
forest
Quote from: ramset on July 15, 2010, 11:57:58 PM
bolt
Chet
Ps
Exactly we need to replicate pistol shrimp electrically  ;D
dole
Hi,
I suggest to start from the beginning, marvelous ting is when you go back and read, you may discover something new, something new in his (yours) mind, something simply overlooked. Very often I do not understand, but I don't mind this is just question of time and adjustment.
http://rapiddigger.com/download/nikola-tesla-lectures-patents-articles-rar-3945190/
or
http://www.amazon.com/Nikola-Tesla-Lectures-Patents-Articles/dp/0787306347
d.
ps.
I hope that is original one, Beograd 1956 (important), If not I may help with original I have.
(You may find some miss correction in later (newer) writings and interpretations)
Tenbatsu
Sorry this is slightly off topic but I do find the Pistol Shrimp's biological snapping mechanism to be quite interesting.
From Wikipedia:
The snapping shrimp competes with much larger animals like the Sperm Whale and Beluga Whale for the title of 'loudest animal in the sea'. The animal snaps a specialized claw shut to create a cavitation  bubble that generates acoustic pressures of up to 80 kPa  at a distance of 4 cm from the claw. As it extends out from the claw, the bubble reaches speeds of 60 miles per hour (97 km/h) and releases a sound reaching 218 decibels.[8]  The pressure is strong enough to kill small fish.[9]  It corresponds to a zero to peak  pressure level of 218 decibels relative to one micropascal (dB re 1 μPa), equivalent to a zero to peak source level  of 190 dB re 1 μPa at the standard reference distance of 1 m. Au and Banks measured peak to peak source levels between 185 and 190 dB re 1 μPa at 1 m, depending on the size of the claw.[10]  Similar values are reported by Ferguson and Cleary.[11]  The duration of the click is less than 1 millisecond.
The snap can also produce sonoluminescence from the collapsing cavitation bubble. As it collapses, the cavitation bubble reaches temperatures of over 5,000 K (4,700 °C).[12] In comparison, the surface temperature of the sun is estimated to be around 5,800 K (5,500 °C). The light is of lower intensity than the light produced by typical sonoluminescence and is not visible to the naked eye. It is most likely a by-product of the shock wave with no biological significance. However, it was the first known instance of an animal producing light by this effect. It has subsequently been discovered that another group of crustaceans, the mantis shrimp, contains species whose club-like forelimbs can strike so quickly and with such force as to induce sonoluminescent cavitation bubbles upon impact.[13]
The snapping is used for hunting (hence the alternative name "pistol shrimp"), as well as for communication. When feeding, the shrimp usually lies in an obscured spot, such as a burrow. The shrimp then extends its antennae outwards to determine if any fish are passing by. Once it feels movement, the shrimp inches out of its hiding place, pulls back its claw, and releases a "shot" which stuns the prey; the shrimp then pulls it to the burrow and feeds.
It seems that the pistol shrimp produces this high energy cavitation bubble by snapping its claw shut at an extremely fast speed.  There might be more to it though such as frequency, pitch, resonance with the water, or some other obscure factor.  But at the heart of it it seems that the snapping action is the key.  I think there might be a way to replicate this action electronically/mechanically but I do not have enough knowledge to put it together.  Perhaps collectively we can think of something that can work.
dole
Quote from: Tenbatsu on July 16, 2010, 10:14:51 AM
Yes it is possible and it’s simply calls “Capacitor Discharge”
d.
