0 Members and 177 Guests are viewing this topic.
ramset
forest
Quote:
but clearly RF is not RE
A means to an end?
one [RF] done properly ,can bring the other [RE].
Well ,I believe the magic is in the confusion,
The Pulse! The Punch!
Its not just any "BANG", in the case of the only example we have to talk about[the pistol shrimp]
Its design specific ,engineered,purpose built!
Its a pulse "DESIGNED" to break the bond that holds things together in our universe.
                           Special!
If you could plot that pulse,see it,and copy it?
we could open the same door!
And obviously "rapid fire" the pulse and keep the door open.
So we have stored energy ,a special shape,a pulse caused by the two,
and the door opens!
Some call it "cavitation".
Electrical cavitation??
That would be nice!
HHMMM....
I keep thinking of GK's stun gun.
Chet
PS
bolt
The lord also said .
     "Knock"
" and the door shall be opened"
Thanks Grandma
baroutologos
@Bolt,
Yes, indeed after Naudin re-adjust his claims from OU to under-OU, this thread has been silenced a bit.
Now, the talking continuous about shirmps, pulses, RF=RE, caps and resonance etc etc.
Our inability to replicate Kapanadze device partially flows from our inability to interpret what we see at first place.
IMO
Kapandze device is a pump of surrounding energy, like a sinkhole. The energy is supplied via the one ground as (it appears ) AC electricity. The device only sucks energy from environment, does not create itself (as per nuclear trasmutation or ferrite energy theories suggest etc) . This is beautifully demonstrated by Kapanadze when a poor ground, makes the output equally poor (radiator instead of pipe). Excellent ground, maximum output (water mains). No ground, minor or insignifficant output. (as much is fed to device minus losses)
IMO, we should forget all the processes that make a system isolated or stand alone unit. Grounding is not an auxiliary part of kapanadze device as per Kapagen. Grounding is the "plug" that brings energy. The ground is not closed circuit. (two grounds) It is only one.
Unless, we can make a device bearing this profound concept, no Kapanadze device can be replicated, ever.
exnihiloest
Quote from: e2matrix on July 17, 2010, 01:13:35 PM
JLN may not be claiming OU but I am sure OU is available with this device or at least the Kapanadze device.  People have just been taking the simpler route shown by JLN but he doesn't even have ferrite in the core....
I have tried with a ferrite core and it makes no difference.
Kapagen is not OU and Kapanadze device will be OU when il will be duplicated by an independant team. Until now it is not.
What_The_Flux
Quote from: dllabarre on July 16, 2010, 11:26:22 PM
There may not be OU with the Kapagen but there sure is something interesting going on when I can light 18 x 100 watt light bulbs with 750 watt Mains input.
My measurements were taken over 50 feet from my Kapagen and I used a FWBR with an analog meter as was requested of me on this thread for a fairly accurate measurement.
Am I the only one not at all impressed by lighting 18 100W bulbs with 750 watts?
Light is generated by exciting the electrons in the tungsten or halogen or neon or whatever, and emitting photons.
Our society's way of lighting bulbs is to pump painfully slow moving electrons at 60Hz and very low voltage (relative to the electron's bond) through some metal or gas medium. By doing this we get light, but also a lot of heat. That's included in the bulb's watt rating.
By converting to HF/HV we can be way more efficient at getting photons out.
The 100W rating on a bulb ONLY applies to low frequency, low voltage conditions.
If we want to save the world a buttload of energy, let's rewire all our houses to accomodate 50KV at 100MHz. Go ahead, I dare you.
We could even run bulbs off of one wire!
But obviously the power companies didn't design things that way for lots of good reasons.
I'm also a big fan of JLN... he's taught me a lot. But in this case, IMO, he hasn't recreated anything remarkable, just an HV transformer. I think it's misleading to name his device anything that starts with 'Kapa', because he has not even begun to create a resonant circuit, which is what Kapanadze says is the key. I hope to see his experiments continue along these lines.
Whether Kapanadze is real, I don't know. But the concept of working with resonance is fundamentally sound, at least in the sense that it minimizes input requirement by putting voltage and current out of phase. Whether that also can pull extra energy from the environment, I hope to find out.
e2matrix
Quote from: dllabarre on July 17, 2010, 08:23:52 PM
What are these meters called.
Search ebay for "electric meters" or kilowatt hour meters.  They are the meters that are on the outside of all homes and businesses so you can be billed for your electricity usage.  I would advise getting the non-digital type with the aluminum disk spinner and dials.
