0 Members and 138 Guests are viewing this topic.
bolt
"Voltage on input stayed constant or climbed after dropping to the voltage under load - AS LONG AS THE SUN WAS UP"
This is nothing knew its well documented and witnessed many times on SS OU devices. The ambient background energy is higher in the day then night the difference is roughly a 20% drop at nite usually around midnight to 4.00 am. Its an ambient photon velocity vector from the sun. In high power devices over 10kw the extreme levels of magntic radiation creates disintegration of
electrons "decay" into vitrons and solitrons where they interact with matter to make it luminous. This effect was reported in the Eldridge experiments and the VTA became anti-gravity and started to glow around the edges of the device as matter itself begins to dissolve. This is why UFO's glow.
The power drop is more noticeable of high power devices like the TPU, kapandze, Sweet VTA etc but can easy be stabilized thru better control circuitry to stabilize the load same as a voltage regulator.
This technology once OU perfected has FAR reaching consequences other then just lighting your house or running a car. At high power levels all kinds of time and anti-gravity stuff occurs some extremely dangerous in the wrong hands unless you want to find yourself "blended" with local matter itself and have half your body embedded in the floor or ceiling:) This is where your own body mass can preoccupy another time space dimension a bit like paint shop pro MORPHING:)
Gobaga
Quote from: bolt on July 20, 2010, 08:31:42 AM
This is nothing knew its well documented and witnessed many times on SS OU devices. The ambient background energy is higher in the day then night the difference is roughly a 20% drop at nite usually around midnight to 4.00 am. Its an ambient photon velocity vector from the sun. Its more noticeable of high power devices like the TPU, kapandze, Sweet VTA etc but can easy be stabilized thru better control circuitry to stabilize the load same as a voltage regulator.
Stop spreading your disinformation!  Everything you say about these devices is totally wrong.  If you would try to build any of these devices you would know that you don't know anything about them.
bolt
Quote from: Gobaga on July 20, 2010, 09:07:53 AM
And stop trolling! If you don't believe in this stuff which has been built, tested, documented, researched by others then go and take up knitting or gardening instead.
Clearly we are getting to close to the mark the paid saboteurs are on board! This is a good sign:)
Gobaga
Quote from: bolt on July 20, 2010, 09:13:09 AM
Don't rely on others to prove all of your false talk, insolent troll!
Show me one thing you have built that works.  All it takes is knowledge of the coils and how they interact, not a lab full of equipment.
You are as far from the mark as possible and your inflated ego is attempting to lead others astray.  Stupidity loves company!
sadang
Bolt, I like your thinking way. Anyway, there is no OU, only OU (Over Understanding), there is no empty space, and the actual electromagnetic theory is so superficial, nothing is what appears to be... more better is to return to studying science books from 1800! Each one of us should try to read John Worrell Kelly, Leedskalnin, Tesla, Dan A. Davidson, T.J.J. See, Eric Dollard and many others , all who pass beyond the actual science border.
Bolt and others who follow his own path, DON'T STOP!
