0 Members and 1903 Guests are viewing this topic.
bolt
Quote from: albert on July 22, 2010, 08:51:45 AM
Perhaps we could go back to the topic here?
I mentioned the marked difference in day/night performance on the Bedini because
IF this also occurs on the Kapagen replications we can surmise that we are tapping the same energy that is also occurring in many of the other devices
we can see THAT indeed there is an extraneous energy field otherwise the battery voltage would not fluctuate
we can see that the Kapagen device might be slightly or heavily OU or under unity depending on the time of day the measurement was taken.
Therefore I strongly suggest that those of you who have a working device try to measure the output during different times of the day. And do not despair if its under unity it might be different at another hour.
My HOPE is that it would be just complementary to a solar system- would it not be nice if the Kapagen could kick in when the solar panels go out?
All the UFO and other stuff should not touch this topic here IMHO. Its like religion:You are free to believe it or not. I myself try to rely on my meters and my eyesight.
Well unless you chose to run your Kapagen between the hours of midnight and 4 am then its working at peak performance.
I also realize that i forget 99% of people cant even realize  radiant energy even exists let alone some of the advance effects im describing. I wait for a few more years for yawl to all catch up then we can discuss some of the more exciting aspects.:)
albert
You mean we should wait until we get even the simplest radiant energy techniques to WORK and be REPEATABLE? Then I agree. If we cannot even get these primitive things to run we need not talk about 23rd century techniques to run UFOS on.Or antigravity and Philadelphia Experiment stuff...
"Any sufficiently developed technology is indistinguishable from magic".
Arthur C. Clarke's famous "First Law".
"Never ask any free energy inventor how his or her device works. He will be the last one to know."
ALBERTs (not so famous)  "First Law"
Pirate88179
We should probably stick to the topic here at hand and not ufos and the so-called Philadelphia Experiment.
Thanks,
dole
Hi,
Please forget Philadelphia “cheesecake” we are not there yet, I would appreciate some help. Does anybody know good and simple schematic or way of getting (buying)  100% sinusoidal variable freq generator up to 20 000 Hz and output around 300W?
Please this is what I found and it could be totally wrong. I think resonance must be fulfilled in the wired itself first i.e. induction capacity and frequency and further I think this is not coincident that Kapanadze use coaxial cable. I suggest those who still experiment to look in to coaxial cable properties, induction capacity and frequency (I think ferrite may magnify this later) probably this is what Don S. is using or primary. I guess Tesla wound this to, documented as twisted pair but in reality one with twisted shied around enlarged later and called Caduceus coil (It is believed that will generate scalar waves).
Thanks
d.
This is not ground cable !!??
e2matrix
Quote from: dole on July 22, 2010, 07:56:01 PM
Hi,
<snip<
The first thing that comes to mind would be a simple function generator hooked to a high power (and probably high quality) audio amp or stereo system.  Many systems put out that wattage range today.  And most audio systems are capable up to 20 Khz.  That would likely be the cheapest way if you don't need to go much over 20 Khz.
