0 Members and 213 Guests are viewing this topic.
xenomorphlabs
Okay Bolt,
do you think the patents that Kapanadze filed are a distraction too? Just curious.
They sound much more complicated then what you are describing.
I totally agree that Kapanadze probably has no expensive lab down there in georgia, so
he had to improvise.
Okay like in the picture, if you run the spark gap at 50 Hz then you should also get 50 Hz AC onto the load (Rload). But if you run int at radio frequencies then you would need some kind of frequency adjuster as described in the patent to convert the high current frequency down to 50 Hz.
So experimentally (with the 2 grounds), we have to build a Tesla transformer coil now that has exacty a 50 Hz resonance frequency, right?
And then i assume (as you were talking about) some component is necessary to phase shift current and voltage, so they are in phase before the output?
hartiberlin
Hmm,
I already made a test with a sparkgap and
my Newman coil and a 100 Nanofarad cap row in parallel
with the Newman coil a few years ago.
Have a look at these pics:
http://www.overunity.com/newman/2coils.jpg
http://www.overunity.com/newman/capcharge.jpg
http://www.overunity.com/newman/dragone.jpg
http://www.overunity.com/newman/sparkgap.jpg
http://www.overunity.com/newman/glow15ma.jpg
The last picture shows the 25 Watts bulb glowing just in series
with the Newman coil and the sparkgap and the 620 Volts DC power supply.
The glowing came from the huge radio frequency burst currents flowing
on the power supply line,
but the DC ampmeter just showed only about 15 mA input current.
(via a shunt on the MilliVolt meter)
If I would have used a low turn secondary coil around the Newman
coil then I could have probably lighted up the 25 Watts bulb there to
full luminance , cause it would have had better impedance matching.
I remember hearing a simular sound when the sparkgap
was hissing like in the Kapanadze video.
So it could really be true, that Sparkgap excited big aircoils
can have a huge magnetic flux break effect, so the BackEMF goes
into very high Kilovolts ranges.
I even blew many of these series caps at this
experiments, although each one had already about 500 Volts
ratings and I had many in series to get a higher votage rating...
Regards, Stefan.
bolt
No its not a distraction he wanted to cover enough to enable a patent without giving away all of the design aspects.
Look in order to separate the entropy cohesion on magnetic flux versus electrical flux you need to go to RF and RF starts at 50Khz. Once you get there you are on your way to exciting local electrons without consuming current. Electrons move with voltage. Current is AFTER the fact when they try to re-establish normality.
Of course the exciter WILL consume current nothing we can do about that but the magnetic induction into another resonance coil will energize nearby electrons that were NOTHING to do with the original energizer process. These electrons become additive and are REAL and this is where the OU comes from.
Kapanadze simply pumps the ground electrons instead and because ground ELF magnetic fields are so low you need to space some meters apart to capture a small portion of the wavelength. We are talking tiny weeny fractions of an ELF earth field in this system so the wider apart you have put the earths the better it works.
During the process however the pumping energizer frequency is usually much higher then required on the o/p  so third coil is fed into a bank of power factor correcting capacitors to change to the lower 50/60 hz we require.
You do NOT have change hi frequency through hetrodyne and PF correction. You can in fact put a FWBR and feed the HF AC to DC and use that. This is EXACTLY what the TPU does. What you are left with is DC with 5Khz riding on top which was part of the energizer process. That said the TPU ring is self resonance at ANY arbitrary frequency it likes to self oscillate at there is NO magic frequencies thus the small TPU could be running 3 to 10 megs and the large one 800khz to 1.5 megs. From say 1000 volts DC at 50 amps you can then use a modified mains inverter instead to convert to mains 110/240 whatever.
If you want to know more about this stuff with many more circuit examples and complete understanding read everything you can find on Don Smith because this is ALL Tesla systems nothing more nothing less.
Volts = stress potential = joules x frequency
Left hand spin on local electrons produces right hand spin magnetic induction back to coil.
power = volts x amps.
Thus when we double the ambient voltage (ground waves or air)  power increases by a factor of 4.
Quote from: xenomorphlabs on July 12, 2009, 12:16:55 PM
Okay Bolt,
bolt
Very good Stefan,
You are half way there as most reach this stage with imoptep CFL systems etc but not fully realizing how to gather more free electrons then spectacular results are not seen. That said everyone that plays with hi volts and coils start to see interesting things:)
Quote from: hartiberlin on July 12, 2009, 12:27:47 PM
Hmm,
Regards, Stefan.
Kosh
Quote from: bolt on July 11, 2009, 02:06:26 PM
"never would be able to supply 50 to 100 KWatts from
the pictures I have seen from his "small" coils."
Mmm you can in fact because these systems rely on VARS where the volts and amps are generated out of phase. If volts and amps are out of phase then there is NO power at that point in time therefore there is no heating.
Tell that to the electric power company... They would stop asking for power factor correction.
Proof take a antenna say 4 watts input 27 meg CB aerial.  At the end of a dipole you can actually measure maybe 1000 volts. In the center you can measure incredible currents like 1000 amps. Why doesn't this burst in to flames? Simple the current and volts are real but they are out of phase as VAR volts amps reactive in resonance. For as long as we keep the voltage and current in different time domains then you can have incredible amount of power running through very thin coils.
Not in our real antenna world. Antenna wires for high power are thick.
By making a last moment conversion you can have REAL power where 1000 volts X 1000 amps = 1000000 watts. When you learn how to do this conversion then you have all the power you could ever need. Please don't tell me it cant be done because the Kapanadze device is doing this in the video.
This is just speculation. We don't know exactly what Kapanadze's device is doing.
And extracting real power from VAR would be the 'Holy Grail' of electric power generation.
