0 Members and 88 Guests are viewing this topic.
stivep
Title:Unusual behavior of Free Energy Device component
http://www.youtube.com/watch?v=9F6xqUwhZrU
Purpose of Investigation:
Fallowing Investigation was provided by means of observing random effect noticed at the scope of NA. The investigation was not planed nor prepared.
Investigation is the documentary of event.
Duplicability of this documentary event is unconfirmed as of yet
we will name it: DUT
(abbreviation : DUT - Device Under Test)
1 component description: TOROIDAL TRANSFORMER (DUT)
a. toroidal transformer consisting primary coil and 2 secondary coils
b. secondary coils are connected in series
c. secondary coils are winded in opposite direction
d secondary coils are at fixed position randomly chosen.
e. resonant point is not conformed as maximum energy transfered.
2. Testing Device description: Network Analyzer Advantest R3267
( abbreviation NA will be used)
3.Frequency range set for 10KHz to 150MHz
4.Connection description:
a. primary coil connected to Network Analyzer
connector used 2 short lids of coax 50 Ohm ( input A)
lids are calibration- compensated
b. secondary coil connected to Network Analyzer
connector used 2 lids of coax 50 Ohm (output1)
5.Channels utilized;
Channel 1 of NA
Channel 2 of NA
6. Channel assignment:
a.
One channel was used to provide standard relation Line Magnitude versus Phase ( that characteristic was showing stable pattern)
selected display button input ports of NA: A/R
While another one was used with various of display modes
That characteristic was showing very unstable pattern)
Explanation:physical connection of NA
-Output 1 (50ohm) connected to DUT
-Output 2(50ohm) connected to input R(ref.)
-Input A connected to DUT
b.
Both of the channels are of the same ports of NA and "watching" the same signal.
conclusion1:
The "network" behavior was unstable while observed on NA only on the channel that was switched to A
(selected display button input ports of NA: A)
conclusion2:
a The theory of Vladimir Utkin might be assigned to explain observed phenomenon
b. If statement from point (a) of (conclusion2) is to be accepted than we have evidence of correlation of capacitance of the coil (1a) with respect to
input / output signal. creating signal amplification
Mentioned signal amplification is NOT TO BE ACCEPTED BY OFFICIAL STANDARD SCIENCE
Message from the author:
I do not make any statements of OU. For me to make such statement much more of experimentation is needed.
stivep
for better understanding how Network analyzer work please  watch also video #12
prior to new video #13
http://www.youtube.com/watch?v=XhDcADo7jjM&feature=player_embedded
All of the findings have to be investigated further to confirm that no misinterpretation was found.
Wesley
innur
Quote from: justasm on June 29, 2009, 08:02:28 AM
BTW: he destroys his device after each demonstration.
why?
There are so many approaches to get energy and many seem to be working.
But as far as you try to rebuilt those units some pieces are missing or hidden?
Anyone got a complete tutorial how to built a Kapanadze device ? This where no part is moving.
Any help is welcome
Love and Light
<3
dole
Hi,
Learning in progress, ferromagnetic material may be used instead of carbon or in combination (presuming that information is correct). Anyway seems the core must be divided.
http://www.ferrocarbon.it/deliv_b.html
http://www.ferrocarbon.it/discover.html
http://en.wikipedia.org/wiki/Electrochemical_Regeneration
d.
