0 Members and 103 Guests are viewing this topic.
stivep
Quote from: exnihiloest on August 17, 2010, 05:53:15 AM
I think that people (at least me) are interested in raw informations allowing to build a free energy device or giving realistic attempts or keys to it.
Filtering the informations according to the idea that one could have about the possible psychological effects they can induce, is for me outside of any scientific/rational method and miss the point of this open source forum.
Do you call this  Quote: "NON realistic attempts or key to it." ?
Compare this translation to the one that was given by Quote:" RAW  INFORMATION TRANSLATOR."
Will that Raw translation allow to Quote:" build a free energy device" ?
is this translation  comparing to Raw one for You Quote: "outside of any scientific/rational method and miss the point of this open source forum"
NONSENSE my friend!! NONSENSE!!
Coils W1 and W2 have the same number of turns, but they have different sections(could be:directions of winding and/or winding distance between winds) of wire. Because these coils are connected in oposite directions , then their total summary inductance is very small. If the conductor diameter of one of the coils is equal to 0.1 of another section, the resultant ampere per turn is reduced by only 10%. But the necessary inductive, eddy current obtained in our DUT is to be noticed at frequencies up to 300 MHz. In addition to our DUT ferrite material is used for the purpose of amplifying  EMI and EMF of DUT
DUT- device under test
EMF-electromagnetic field
EMI- electromagnetic inductance
During  the test -recording of spectrogram  of properties was provided.
Some parameters were measured using indicator (I)(measurement tool),
connected to coil W3 of the rod (CT), which could be made of the same  material (content) as the DUT.
So to say, the material of the rod ST  is the same as our  core of transformer made from (inner) iron, or  to be more accurate iron-nickel alloy,
Magnetic “flow”  induces in the DUT,  longitudinal current inside( at the) of the ferromagnetic ring.
In some of the moments during the test, the density of the pulse current was at the level of  107 A/mm2.
Because of the current that is given at this density we will have to deal with  typical evaporation and melt due to abnormal heat, What we have to do is  to deliver the currents on the primary coils in the form of short pulses (up to 0.1 ms).
The Constructive Componet of our DUT is factor of -  constant bias for the
Circuit 2 â€" 2 and ,it is  being used as the one that is providing  effective magnetizing field, and that is why
winding W1 and W2 are being seen  by that circuit as connected in series- (consistently).
Thanks to the described experimental setup we  have been fortunate to  detect  change of
steady subatomic order.
Trastos
Quote from: stivep on August 17, 2010, 11:14:49 PM
I Think that this is the way, thanks at all, good work.
Is cleary that the "Tesla direction" is good for advance, i'm reading the colorado springs notes, is one of the basic concepts for kapandze, like the algebra to the ecuations.
PD: I have read this topic every day, and more documentation, for all please, stop discussions about people.
Shokac
Does anyone know which frequency is used SR?
I have same (i think) toroid like SR, but i don't know frequency, and don,t know duty cycle (%) of the signal.
Shokac
Quote from: Trastos on August 18, 2010, 01:53:10 PM
I agree with you! But first, you must visit his birthplace.  :)
http://www.gospic.hr/info/Mem_centar_Nikola_Tesla.asp#15
